Why is it that when I convert an avi or divx file to mpeg with TMPGEnc and I choose Pal 16.9 when encoding I end with the result that the picture is full screen instead 16.9?
Hello from the island of Malta.
Hi Selena21,
If you go through the project settings, there's a place where you can select the target you are looking for. You need to specify whether you want Full Screen or Centered output. My guess is you want to select Full Screen with the option to Maintain Aspect Ratio, assuming your source is in a widescreen format.
Cheers!
TTWC"I've got a present for ya!" - TTWC -
TMPMGEnc: Settings button / Advanced tab / Video arrange method
Now I found it.Thanks
What settings shall I choose to have 16.9 movie? I don't want it fullscreen as the people looks long in it.
If the source is not 16.9 it has to remain as that or with the new settings it will end 16.9?Hello from the island of Malta.
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
tmpgenc 2.5 plus problem
By DSLGuy in forum Video ConversionReplies: 1Last Post: 3rd Apr 2008, 15:38 -
Problem with TMPGEnc
By The Monkees in forum Video ConversionReplies: 2Last Post: 1st Nov 2007, 16:58 -
TMPGEnc Problem
By djkevyb in forum Newbie / General discussionsReplies: 3Last Post: 27th Sep 2007, 16:46 -
TMPGEnc Problem !!!!!!!!!!!!!
By homantam in forum Newbie / General discussionsReplies: 2Last Post: 10th Sep 2007, 18:56
