Just got my Toshiba D-R4 this past weekend and it seems like the remote that came with it does not work. Try using brand new batteries and its still isnt working I then went ahead and program my Harmony 880 and it seems to work... I was messing around with the setting on the dvd recorder and now the IR code is set to DR 3 instead of DR 1. Now my Harmony 880 is also not working with the recorder. All I get now is a display of DR 3 when I try using my Harmony 880. My question is there any way I could change the IR code back to DR 1??? I have looked in the manual and I cant seem to locate a way to change the IR code back to DR 1.... This recorder is pretty useless without a working remote... I'm sooo pissed at myself right now!!!! Anyone???
Look on pages 44 and 45 of the installation guide, not the owner's manuel. It will tell you how to change the recorder and the remote from DR 1 to DR 2 or DR 3. To change the remote you hold the * button plus 1,2 or 3 to change the remote.
Remote Control Problem with new Sony SR500H DVD player
By Bass Cadet in forum Newbie / General discussionsReplies: 3Last Post: 27th Jun 2011, 13:56 -
ATI remote control
By lazybum in forum Capturing and VCRReplies: 2Last Post: 12th Jun 2009, 18:19 -
Universal Remote Control
By titilucky in forum DVD & Blu-ray RecordersReplies: 11Last Post: 3rd Nov 2008, 15:31 -
Original part# remote control f/ toshiba Sd -3960
By thebirdf in forum Newbie / General discussionsReplies: 0Last Post: 20th Jun 2008, 16:17 -
Remote Control Problem - Pioneer DVR-330-S
By wmedia in forum DVD & Blu-ray RecordersReplies: 4Last Post: 25th Mar 2008, 08:31
