  1. Way I have a bunch of avi's well over 100 actually its there a way for me to make a batch of them and have it extract each 1 seperately ? I know you can probably do it with a batch job in vdub but then there'd be no different then me opening and saving each audio. You guys know what I mean ? I tried eo video but it gave me some errors some yes comments please
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    "Extract" to WAV ? Or demux ?
    If in doubt, Google it.
  3. yeah wav is good, speaking of which normally when I'm in vdub and I want to extract the audio, other then the size does it matter if I leave the audio in direct steam copy or full processing mode ?
  5. Hey, I only have ac3 and mp2 as an option in ffmpeggui. Also I highlighted a bunch of files but it only selected 1.
    Dec 2004
    Australia
    ffmpeg supports encoding to:
    aac
    ac3
    adpcm_4xm
    adpcm_adx
    adpcm_ct
    adpcm_ea
    adpcm_ima_dk3
    adpcm_ima_dk4
    adpcm_ima_qt
    adpcm_ima_smjpeg
    adpcm_ima_wav
    adpcm_ima_ws
    adpcm_ms
    adpcm_sbpro_2
    adpcm_sbpro_3
    adpcm_sbpro_4
    adpcm_swf
    adpcm_xa
    adpcm_yamaha
    amr_nb
    amr_wb
    g726
    mp2
    mp3
    pcm_alaw
    pcm_mulaw
    pcm_s16be
    pcm_s16le
    pcm_s24be
    pcm_s24daud
    pcm_s24le
    pcm_s32be
    pcm_s32le
    pcm_s8
    pcm_u16be
    pcm_u16le
    pcm_u24be
    pcm_u24le
    pcm_u32be
    pcm_u32le
    pcm_u8
    sonic
    vorbis
    You just need to use it without the GUI. Much better for batch encoding anyway. If you just want PCM, then mplayer is probably better anyway mencoder.exe -ao pcm:file=output.wav -vo null -vc dummy input.avi
