Hi,
I spent HOURS reading here and downloading and installing software to no avail......
I was wondering how to do what i think must be easy but seems difficult. I can rip DVD/VOB's to my hard drive no problem. But then i might want to cut out a couple scenes for my personal enjoyment. This seems very difficult. I can find programs to make cut points but then I have to take time to re-code it which seems like a waste of time. Also I can make avi files no problem but of course that means recoding as well.
Ideaslly it would work like NanDub, a simple preview window where I can make marks hit go and a few seconds later there is a edited vob.
I would love to know what easy free tools there are like on this site as well as pay software from companies like ULEAD etc. I have the hardest time finding a tool that specifically does this!
Thanks alot.
Maybe VOB2MPEG then Cuttermaran? Both freeware. There's probably a lot of ways. You shouldn't have to re-encode it, but you will have to re-author it if you want it back in DVD format.
Yeah, there are a bunch. Personally, I'm partial to MPEG2Cut. Others prefer ChopperXP:
http://www.digital-miner.com/chopperxp.html
Don't know why you had trouble finding a tool that does what you want. -
Womble MPEG Video Wizard! It's a bit expensive but worth it, and it has a 30 day free trial
videoredo!
or cut with dvd shrink in the reauthoring mode.
Video split between 2 VOB's
By darkdream4 in forum DVD RippingReplies: 5Last Post: 3rd Jan 2010, 06:45 -
Simple way to join mts files with stream copy (no recoding)?
By MJ Peg in forum Video ConversionReplies: 32Last Post: 1st Oct 2009, 07:29 -
Split chapter VOB ???
By sabercats in forum Newbie / General discussionsReplies: 2Last Post: 18th Feb 2009, 17:48 -
Split VOB chapters without re-encoding everything (must be freeware)
By fmcf in forum Video ConversionReplies: 4Last Post: 23rd Nov 2008, 00:37 -
Crop black bars from .mkv files without recoding
By Gillie in forum Video ConversionReplies: 5Last Post: 14th Oct 2008, 17:04
