You can change your external ip through your router any time you want.thats what you said.You can manually release it and get another number
still awaiting your step by step instruction on how to do this via my router.
Results 31 to 36 of 36
That is your job, not mine.Originally Posted by isogonicBelieving yourself to be secure only takes one cracker to dispel your belief.
On a DHCP server, you select the scope of ip addresses that are not to be used. From there, addressed get assigned. I said it could be done. You said it could not. I am talking about network engineering, not cable systems. I also did this when I had verizon dsl and they do not use PPPOE. Now I bow out of this discussion.Originally Posted by InXessBelieving yourself to be secure only takes one cracker to dispel your belief.
Not sure if it would work in your case, but whenever we have a connection problem with DHCP, we issue the "ipconfig /release" command to release the IP address from the adapter.
Dv8ted2 said:
no dude, you said i could do it anytime. so again tell me how. i will take one time nevermind 20.That is your job, not mine.
the fact is if i didnt tip you off about MAC cloning you would still be insisting i could change it via my router. so i wait for your instruction. -
Children children children ......
If you have MAC cloning available on your router, you can do it pretty much at will. It's more likely that you can do it if you have DSL or ADSL also (as opposed to cable), due to the way most ISPs are set up.
Of course there's caveats to the above.
Y'all can stop threadjacking now.If in doubt, Google it.
This website
By Will Hay in forum Off topicReplies: 24Last Post: 17th May 2013, 18:11 -
ISP problem - some website pages load, other website pages don't
By PartingShot in forum ComputerReplies: 15Last Post: 7th Sep 2012, 00:42 -
vod website
By bobmane in forum Video Streaming DownloadingReplies: 1Last Post: 7th Feb 2012, 12:59 -
vod website
By bobmane in forum Video Streaming DownloadingReplies: 0Last Post: 7th Feb 2012, 06:52 -
RipDifferent Website
By Eragon in forum MacReplies: 2Last Post: 10th Jan 2008, 09:29
