I have two quick questions regarding hardware MPEG2 encoding cards/external devices. I am thinking about going this route because I don't plan on doing any fancy editing after capturing video but was curious if going this route, are you still able to break the final video into segments without having to decode it?
Also what MPEG2 cards produce good results?I looked over some of them in the capture cards section but was hoping to get some tips from you pros. Thanks!
Results 1 to 18 of 18
You can edit the video with a MPEG editor like the freeware Cuttermaran or payware ones like MPEG-VCR or other ones here: https://www.videohelp.com/tools?s=107#107
The Hauppauge WinTV PVR-250 seems to be one of the more popular hardware encoder cards. -
Originally Posted by porigromus
I tried the same route a couple of years ago and decided a Pioneer DVD recorder was the best bet for me. (It's about the same price as a good MPEG2 card.) The quality is high, and my computer is free for other things while the DVD recorder is busy. If I ever feel the need to customize a DVD I'll rip it to my computer with DVD Decrypter or TMPGEnc DVD Author. When I need to edit, Womble MPEG Video Wizard does the job well. After that I re-author it with TMPGEnc DVD Author or Ulead DVD Workshop 2.
I have a Hauppauge USB2 PVR and it works pretty well. It uses an encoder from Conexant (http://www.conexant.com/products/entry.jsp?id=9) and I would assume any card that uses one of these two chips would probably do a pretty good job. Mine came with uLead DVD Movie factory, which does an acceptable job of making VCDs (don't have a DVD burner). I also tried the trial of VideoReDo and when I want to archive video VirtualDub Mod and transcode to MP4.
I have a PVR-250. It works great, but if you plan to capture analog tapes, you'll probably need an external TBC / Frame Synchronizer to keep audio and video in sync. I use a DataVideo TBC-3000.
The DVD Recorders that I have tested all have built-in Frame Synchronizers, so they may be a lower cost solution for tape transfers (if MV is not an issue). -
The best hardware MPEG capture cards/devices for the computer:
Hauppauge WinTV PVR 250 (PCI)
Hauppauge WinTV PVR 350 (PCI)
Hauppauge WinTV PVR USB2 (USB 2.0 external)
ADS Instant DVD 2.0 (USB 2.0 external)
If you decide to go with a stand alone DVD recorder look at Pioneer, Toshiba and JVC as the top three brands around.
- John "FulciLives" Coleman
P.S.
Please avoid the Hauppauge WinTV PVR 150 has it has several unresolved issues."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
Hauppauge WinTV PVR 250.
But get a DVD recorder if you're not interested in doing edits and author your own DVDs.
If you are, you'll have to rip and disassemble the DVD first - a completely unnecessary (and tedious) step.
/Mats -
Originally Posted by mats.hogberg
Hauppauge does make a nice card though, if you want to go the PC route.Want my help? Ask here! (not via PM!)
/Mats -
Losing your computer while it records video is a hassle too. It all depends on how you look at it.
Hardware encoder cards (I have 250) using quite a low CPU. You are not losing your computer.
The mpeg decoder, responsible for displaying what you capture while you capture takes some 10% system resources (using WinTV) but there are 3rd party applications that doesn't display anything while capturing, eliminating even that cpu load.
/Mats -
Trying to use a computer while it processes video is not good, ever.Want my help? Ask here! (not via PM!)
We'll never see eye to eye on this - all I can say is that I use the 250 card daily to record TV shows, and use the same computer for all other computer stuff i do - play games, write, develop applications - And I've never had the occation to say
"Damned, right, I shouldn't have done that while capturing!"
Neither with respect to my capture, nor to what other stuff I might do. YMM obviously V.
/Mats -
I'm capturing L&O SVU as I type this, and if I screw that show up the OL will never let me live it down...
HDMI/DVI to PC hardware card
By ima2hd in forum DVB / IPTVReplies: 24Last Post: 13th Apr 2010, 10:20 -
VHS/Beta Tuner MPEG2 from capture Card to Compress to Smaller File; HELP
By gauthijm in forum Newbie / General discussionsReplies: 1Last Post: 7th Aug 2009, 09:05 -
Best hardware capture card for Beyond TV
By videoguy01 in forum Capturing and VCRReplies: 0Last Post: 22nd Feb 2009, 13:39 -
Best hardware mpeg2 encoder (under 700 $)?
By Speed Demon in forum Capturing and VCRReplies: 27Last Post: 6th Sep 2007, 10:01 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 17:15
