I've done a search on this & found that this is quite a common problem, but no solution found so far.
Before I format my hard drive, my win explorer was able to read all session on the dvd-r created with Nero after ejecting and reloading the disc after burning. Now that I have re-installed the same program (win xp sp2, Nero 6.6.0 & other software I have been using before), the same dvd-r disc my win explorer can read properly earlier will only show the first session now.
I have this problem before but some how it was solved but I've forgotten what have I done to solve it.
Does any body know for sure of the solution?
Thanks in advanve.
ezez, take it eazy
Http://www.ezez.netfirms.com -
Thanks for the info.
I have checked my pc and the udfs.sys I have seems to be quite new ( ver. 5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)).
Before I start updating my os (which normally takes ages because I am using dial up connection), just want to know for sure will this problem be solve by updating alone (before I go through the trouble). Any body ?
Unable to disc copy with Nero 6 and Win 7
By cobra jet in forum Newbie / General discussionsReplies: 5Last Post: 4th Oct 2011, 12:38 -
Disc was not finalized properly
By Phil Kocinski in forum Authoring (DVD)Replies: 3Last Post: 26th Feb 2011, 23:34 -
Can you add custom thumbnail images in win 7 explorer?
By Rudyard in forum ComputerReplies: 0Last Post: 7th Jan 2011, 04:03 -
Can only read the first session in a MultiSession recorded DVD?
By demf in forum DVD & Blu-ray RecordersReplies: 1Last Post: 19th Sep 2007, 12:16 -
Working on old win 98/Me pcs. I don't have a boot disc floppy
By Denvers Dawgs in forum ComputerReplies: 21Last Post: 7th Sep 2007, 18:10
