Hi,
I'm new to DVD authoring and DVD Lab Pro. I've created a few buttons and have given each one labels, as shown in the image below. However, having filled in the "Button Label" property for each button, the label does not appear on each button. Can anyone help with this?
Cheers,
Sean
Button labels are used for special instructions. This is from the help file...
If you want text to show then you need to put a text object. But... if you make the text and the button square part of the control then they both turn the same color when you select them.There are these functional commands DVD-lab expects to be placed inside the button label:
place
placeholder
up
prev
previous
next
number
All other labels are non functional and simply ignored during building the Menu.
See this discussion for more information on that.
Take some time to go through the help system or the on-line version available here -
by the way, you misspelled "jungle" in your title.
I said I'll be done in a minute. I meant a Microsoft minute.
DVD Lab Pro help! Play animation after pressing button for playing video.
By visualhippocracy in forum Authoring (DVD)Replies: 3Last Post: 26th Mar 2011, 09:21 -
DVDlab Pro: Text set as visible isnīt visible in the result
By Alex89 in forum Authoring (DVD)Replies: 14Last Post: 12th Aug 2010, 08:09 -
need to swap images in and out via button states in DVD Studio Pro 4
By theMonseignuer in forum Authoring (DVD)Replies: 2Last Post: 26th Jul 2008, 12:06 -
multi menus (in DVD LAB PRO 2) with different formats/Button issues
By dblue in forum Newbie / General discussionsReplies: 11Last Post: 18th Oct 2007, 19:10 -
Video not visible in editing software/visible in Media Player
By kb1985 in forum Newbie / General discussionsReplies: 1Last Post: 1st Aug 2007, 19:21
