Hi,
I have a divx video and the audio is encoded with vbr, I am trying to encode so I can burn it as a dvd but because of the vbr, the audio is out of sync.
I went into vdub and managed to get the wav but I'm not sure how to add it back to the video to solve my problem, if I click save avi it makes a huge file that is far too big to fit on my hdd, is there a way to just add the new track to the existing video without taking up lots of space?
add the wav audio, audio->wav file,
select video->direct stream copy
then save as a new avi. -
I don't use external WAV audio source when I encounter a AVI with VBR audio
I set VDub audio to "full processing mode" and video to "direct stream copy"
then I change audio to PCM Uncompressed format and interleave it with video every 1 frame, but without preloading anything or delaying anything
This method usually solves my audio sync problems with VBR -
There is no reason to put the audio and video back together if you are going to convert the video to MPEG-2 DVD spec. The combining of video and audio is done in the DVD authoring stage.
AVIsynth -- how do I add an audio wav to a video only clip.. [SOLVED]
By vhelp in forum EditingReplies: 7Last Post: 19th Nov 2013, 06:27 -
help syncing audio .wav of music to video of musician
By tspnyc in forum AudioReplies: 6Last Post: 1st Dec 2010, 18:27 -
Adding audio (wav) to video (avi) (want to delay start of audio)
By Lanton in forum Newbie / General discussionsReplies: 2Last Post: 12th Apr 2010, 13:50 -
Add Audio to video not working in VEGAS
By beavereater in forum EditingReplies: 1Last Post: 16th Apr 2009, 13:07 -
How to convert any video or audio to WAV using mplayer
By Baldrick in forum AudioReplies: 12Last Post: 15th Nov 2007, 02:08
