Hi, hopefully someone can help out with this. I have several AC3 files (5.1) for different audio tracks for a project I'm working on. I need to do a simple fade out for the end (about a minute or so) of the tracks (as I've made a cut to the video), and one of the other AC3s needs to have some silence removed at the front end, and a small trim to remove something in the middle of the track. Can anyone recommend a workflow to accomplish this? I've got temporary access to Maven3D Pro (which oddly wasn't able to convert more than the first minute or so of the AC3 to Wave format...) and was planning to use that to compose each audio and compress back to AC3.
Results 1 to 11 of 11
Hey, back for more
Maven has proven to be a bust for me, and my time with that machine is up. Maven just flatly refused to output anything more than the first 1h22min of the project, despite premixing, and playing fine in the editing window. BeSweet seems to have created the 6 mono wavs nicely though. Soooo, does anyone have suggestions for how to do the fade-out and to compose the 6 files back into a 5.1 AC3 file again? I suppose I could edit the files separatly in something like GoldWave, but then I'm still stuck with 6 separate wavs, which BeSweet (to my knowlege, admittedly limited) can't compose into a single file. Any one have thoughts, or preffered method/packages to share? Thanks again, guys!
Nuendo has capability to edit AC3 file, but the software is costly and you have to have AC3 plug-in which is added cost.
Also Nero 7 has some feature to edit AC3 file but I am not sure how good it is as I have not tried
Best way to do basic editing to dvd video?
By Sebastian2011 in forum EditingReplies: 15Last Post: 4th Apr 2012, 10:54 -
Need Basic Video Editing Software - PC
By Bascotie in forum Newbie / General discussionsReplies: 7Last Post: 12th Feb 2011, 07:15 -
just a basic all around video editing program
By malakov08 in forum MacReplies: 6Last Post: 29th May 2009, 23:34 -
Basic editing: which Mac program for my DVD editing situation?
By Nuevonik in forum MacReplies: 4Last Post: 8th Jan 2009, 07:06 -
Best / Basic Video Editing Software
By oztek in forum Newbie / General discussionsReplies: 5Last Post: 12th Jan 2008, 21:29
