Can you tell, before you start to make your backup copy, what protection a disc has? The reason I ask is that, for me, getting past arccos adds another step...another 10 minutes...and if I could tell whether or not it had that type of protection, I could rip accordingly.
what is the rush
Load in dvd decrypter (or dvdfab decrypter). It will tell you if any other protections are present.
Another alternative is DVD43. If you use DVDShrink it's more convenient as it decrypts on the fly and runs in the background. It's not updated as often as DVDFab Decrypter, though. As long as it's running, you don't have to worry about the type of encryption. It does not get along well with DVD Decrypter if it's running at the same time and you are using DVDD to burn, though. If you use the Nero option, no problems.
Blu Ray and burning a Data Disc...not a Video Disc
By Moontrash in forum DVD & Blu-ray WritersReplies: 16Last Post: 16th Dec 2019, 23:18 -
How to fix "the disc copy protection could not be verified"
By MikeBintouch in forum MacReplies: 3Last Post: 18th Jan 2012, 16:16 -
Copy Protection on a DVD-R disc - how to bypass?
By nerys in forum DVD RippingReplies: 25Last Post: 5th Apr 2011, 00:00 -
Copping Disc - Disc Data Recovery Software.
By Teac23 in forum DVD RippingReplies: 5Last Post: 1st Oct 2010, 21:06 -
Is it possible to rip a HD DVD disc to Hard Disc ?
By fjmr in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2007, 13:50
