Hello,
I have an un-modded EURO PAL SONY PS-2 Model 50004 and I would like to know if it can play original Region 1: US, CA NTSC DVD movies?
I have tried the Japanese NTSC Psyvariar II bonus movie DVD and it worked fine, but what about Region 1: US, CA movies?
Thanks in advance.
The japanese ntsc video might have been region free but normal region 1 movies probably wont work unless its modifed and you are using a scart cable or you use a dvd region free disk with a scart cable
I have never tried but I am pretty sure that is the way it is -
I just found about these PS-2 Region Free Boot-discs:
1.DVD Region X for EURO PAL PS-2
http://us.codejunkies.com/shop/product.asp...=1&l=1&ProdID=3
2.Datel DVD Region X
http://computing.kelkoo.co.uk/b/a/ps_9520983/112201.html
Are these two the same product by the way?
I also found this:
3.Blaze DVD Region Free
http://computing.kelkoo.co.uk/b/a/ps_9514905/112201.html
Which one is the best? -
I'd go for !.
If it was me
Also make you your tv can handle the ntsc signal or use scart cable
Also if you have the latest matrix infinity firmware you might be able to do all this with your chip
(some people say you cant do it but I have never actually tried)
Converting DVDs from Region 1 (NTSC) to Region 2 (PAL)
By Astronautilus in forum Authoring (DVD)Replies: 8Last Post: 10th Feb 2012, 05:35 -
Hack working for Sony BDP-S380 region 1, to make it region free?
By Julieso in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Dec 2011, 17:12 -
Convert PAL Region 2 DVD to NTSC Region-Free DVD?
By wizoomer95 in forum Video ConversionReplies: 6Last Post: 6th Aug 2011, 22:10 -
Sony DVP-FX720 region restriction - using DivX waiting for region free code
By wig in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Aug 2008, 05:34 -
Yamaha DVD w/HDMI remote hack? Region 1 to all region [PAL]?
By eurocd in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Jul 2007, 13:58
