    Apr 2006
    Australia
    Hi,
    I recently installed HDTV2DVD 0.40 on my WinXP SP2 box. When I try to run the application I see the splash screen them immediately get the following error message:
    HDTV2DVD.exe - Common Language Runtime Debugging Services
    Application has generated an exception that could not be handled.
    Process id=0x7b0(1968), Thread id=0x70c(1804)
    Click OK to terminate the application.
    Click CANCEL to debug the application.
    I've verified that I have .Net Framework 1.1 with SP1 installed. I've uninstalled and reinstalled the software and I've also tried HDTV2DVD build 0.41 but the problem still occurs. Is there anything I can do to fix this problem? Or can I download an older version somewhere to try out?
    Cheers,
    George
    Apr 2006
    I'm getting a crash in version 0.4 as well, as soon as a file is loaded from Assets to Layout. Similar setup, XP SP2 with .Net 1.1 loaded, the files are HDTivo .ts, loaded from TyTool 10.4 and edited with VideoReDo Plus before opening in HDTV2DVD. Tried two different episodes of "Battlestar Galactica" and got the same behavior.
    A cut-and-paste of the data in the Windows crash report file follows:
    <?xml version="1.0" encoding="UTF-16"?>
    <DATABASE>
    <EXE NAME="HDTV2DVD.exe" FILTER="GRABMI_FILTER_PRIVACY">
    <MATCHING_FILE NAME="DevComponents.DotNetBar.dll" SIZE="1581056" CHECKSUM="0x6AFF404B" BIN_FILE_VERSION="5.2.0.5" BIN_PRODUCT_VERSION="5.2.0.5" PRODUCT_VERSION="5.2.0.5" FILE_DESCRIPTION="DevComponents.DotNetBar" COMPANY_NAME="DevComponents.com" PRODUCT_NAME="DevComponents.DotNetBar" FILE_VERSION="5.2.0.5" ORIGINAL_FILENAME="DevComponents.DotNetBar.dll" INTERNAL_NAME="DevComponents.DotNetBar.dll" LEGAL_COPYRIGHT="(c) 2002 by DevComponents.com, All Rights Reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x185F0F" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.2.0.5" UPTO_BIN_PRODUCT_VERSION="5.2.0.5" LINK_DATE="10/21/2005 13:29:19" UPTO_LINK_DATE="10/21/2005 13:29:19" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="DVDFolders.dll" SIZE="106496" CHECKSUM="0xB63174C5" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="10/11/2005 13:37:58" UPTO_LINK_DATE="10/11/2005 13:37:58" />
    <MATCHING_FILE NAME="ffmpeg.exe" SIZE="3251712" CHECKSUM="0xE2253217" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3225B0" LINKER_VERSION="0x10000" LINK_DATE="09/23/2005 14:20:29" UPTO_LINK_DATE="09/23/2005 14:20:29" />
    <MATCHING_FILE NAME="HDTV2DVD.exe" SIZE="1613824" CHECKSUM="0xAAF47632" BIN_FILE_VERSION="0.4.2132.24074" BIN_PRODUCT_VERSION="0.4.2132.24074" PRODUCT_VERSION="0.4.2132.24074" FILE_DESCRIPTION="HDTV2DVD 0.4" COMPANY_NAME="Badger I.T." PRODUCT_NAME="HDTV2DVD 0.4" FILE_VERSION="0.4.2132.24074" ORIGINAL_FILENAME="HDTV2DVD.exe" INTERNAL_NAME="HDTV2DVD.exe" LEGAL_COPYRIGHT="Badger I.T." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="0.4.2132.24074" UPTO_BIN_PRODUCT_VERSION="0.4.2132.24074" LINK_DATE="01/01/1970 00:00:34" UPTO_LINK_DATE="01/01/1970 00:00:34" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="Interop.DexterLib.dll" SIZE="65536" CHECKSUM="0x43F5C3A9" BIN_FILE_VERSION="1.0.0.0" BIN_PRODUCT_VERSION="1.0.0.0" PRODUCT_VERSION="1.0.0.0" FILE_DESCRIPTION=" " COMPANY_NAME=" " PRODUCT_NAME="Assembly imported from type library DexterLib" FILE_VERSION="1.0.0.0" ORIGINAL_FILENAME="Interop.DexterLib.dll" INTERNAL_NAME="Interop.DexterLib" LEGAL_COPYRIGHT=" " VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1DDC6" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.0" UPTO_BIN_PRODUCT_VERSION="1.0.0.0" LINK_DATE="09/23/2005 19:43:11" UPTO_LINK_DATE="09/23/2005 19:43:11" VER_LANGUAGE="Invariant Language (Invariant Country) [0x7f]" />
    <MATCHING_FILE NAME="Interop.QuartzTypeLib.dll" SIZE="18944" CHECKSUM="0x90637C09" BIN_FILE_VERSION="1.0.0.0" BIN_PRODUCT_VERSION="1.0.0.0" PRODUCT_VERSION="1.0.0.0" FILE_DESCRIPTION=" " COMPANY_NAME=" " PRODUCT_NAME="Assembly imported from type library QuartzTypeLib" FILE_VERSION="1.0.0.0" ORIGINAL_FILENAME="Interop.QuartzTypeLib.dll" INTERNAL_NAME="Interop.QuartzTypeLib" LEGAL_COPYRIGHT=" " VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x8CAB" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.0" UPTO_BIN_PRODUCT_VERSION="1.0.0.0" LINK_DATE="02/14/2005 19:29:31" UPTO_LINK_DATE="02/14/2005 19:29:31" VER_LANGUAGE="Invariant Language (Invariant Country) [0x7f]" />
    <MATCHING_FILE NAME="S2DProgressBar.dll" SIZE="32768" CHECKSUM="0x569B6FB1" BIN_FILE_VERSION="1.0.2109.17800" BIN_PRODUCT_VERSION="1.0.2109.17800" PRODUCT_VERSION="1.0.2109.17800" FILE_DESCRIPTION=" " COMPANY_NAME=" " PRODUCT_NAME=" " FILE_VERSION="1.0.2109.17800" ORIGINAL_FILENAME="S2DProgressBar.dll" INTERNAL_NAME="S2DProgressBar.dll" LEGAL_COPYRIGHT=" " VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xF474" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.2109.17800" UPTO_BIN_PRODUCT_VERSION="1.0.2109.17800" LINK_DATE="10/10/2005 09:54:22" UPTO_LINK_DATE="10/10/2005 09:54:22" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="stdole.dll" SIZE="16384" CHECKSUM="0xA2506EFF" BIN_FILE_VERSION="7.0.9466.0" BIN_PRODUCT_VERSION="7.0.9466.0" PRODUCT_VERSION="7.00.9466" FILE_DESCRIPTION="" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft® Visual Studio .NET" FILE_VERSION="7.00.9466" ORIGINAL_FILENAME="" INTERNAL_NAME="" LEGAL_COPYRIGHT="© Microsoft Corporation. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xBDFB" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="7.0.9466.0" UPTO_BIN_PRODUCT_VERSION="7.0.9466.0" LINK_DATE="01/05/2002 09:46:32" UPTO_LINK_DATE="01/05/2002 09:46:32" VER_LANGUAGE="English (United States) [0x409]" />
    </EXE>
    <EXE NAME="CEAudio.ax" FILTER="GRABMI_FILTER_THISFILEONLY">
    <MATCHING_FILE NAME="CEAudio.ax" SIZE="147456" CHECKSUM="0xB08899E1" BIN_FILE_VERSION="1.0.0.30602" BIN_PRODUCT_VERSION="1.0.0.30602" PRODUCT_VERSION="1, 0, 0, 30602" FILE_DESCRIPTION="Audio Decoder" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="DVD Audio Decoder Filter" FILE_VERSION="1, 0, 0, 30602" ORIGINAL_FILENAME="" INTERNAL_NAME="" LEGAL_COPYRIGHT="Copyright (C) 2003 Ulead Systems, Inc." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.30602" UPTO_BIN_PRODUCT_VERSION="1.0.0.30602" LINK_DATE="07/16/2003 02:38:09" UPTO_LINK_DATE="07/16/2003 02:38:09" VER_LANGUAGE="English (United States) [0x409]" />
    </EXE>
    <EXE NAME="kernel32.dll" FILTER="GRABMI_FILTER_THISFILEONLY">
    <MATCHING_FILE NAME="kernel32.dll" SIZE="983552" CHECKSUM="0x4CE79457" BIN_FILE_VERSION="5.1.2600.2180" BIN_PRODUCT_VERSION="5.1.2600.2180" PRODUCT_VERSION="5.1.2600.2180" FILE_DESCRIPTION="Windows NT BASE API Client DLL" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft® Windows® Operating System" FILE_VERSION="5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)" ORIGINAL_FILENAME="kernel32" INTERNAL_NAME="kernel32" LEGAL_COPYRIGHT="© Microsoft Corporation. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xFF848" LINKER_VERSION="0x50001" UPTO_BIN_FILE_VERSION="5.1.2600.2180" UPTO_BIN_PRODUCT_VERSION="5.1.2600.2180" LINK_DATE="08/04/2004 07:56:36" UPTO_LINK_DATE="08/04/2004 07:56:36" VER_LANGUAGE="English (United States) [0x409]" />
    </EXE>
    </DATABASE>
