all,
from my movie i want to create a playlist behind a button on the main menu.
this playlist will play a number of short sequences from the movie. say 3 short clips. some are 2 minutes long and others are 5 minutes long.
the way i did this is to create, 6 chapters, then create a playlist to play chapters 1, 3 and 5. a button on the main menu would link to the playlist.
chapters 2, 4 and 6 were splices so that the sequence would go straight from chapter 1 to 3 to 5 and then back to main menu.
this works fine.
my problem is, how to add "normal" chapters for the movie which co-exists alongside the playlist?
when i add a chapter, say every 3 minutes, this affects the above playlist. meaning when i hit the next button whilst in playlist mode, it jumps to the "normal" chapter as opposed to the next link in the playlist.
also, i don't want to create 3 separate mini clips as this would bump up the movie size and i don't have the space on a +5 dvd.
if dvd lab pro cannot do this, can some other authoring app do so?
cheers for any help in advance.
Results 1 to 1 of 1
Software TV Studios use to edit/cut splice logos & commercials etc....
By Moontrash in forum EditingReplies: 11Last Post: 14th Oct 2010, 23:52 -
How do I retain Chapter Points from Movie? [DVD Lab Pro 2]
By SupaDupaMonkey in forum Authoring (DVD)Replies: 2Last Post: 12th Sep 2009, 19:56 -
DVD-LAB Pro 2
By Sanmaame in forum Video ConversionReplies: 4Last Post: 23rd Oct 2008, 05:42 -
DVD Lab Pro 2: Demuxing errors & Chapter Inquiries
By evilpr in forum Authoring (DVD)Replies: 8Last Post: 22nd Jul 2008, 03:40 -
DVD Lab Pro - Play Chapter and return to menu
By SCDVD in forum Authoring (DVD)Replies: 4Last Post: 5th Dec 2007, 17:05
