I have AVI clips taken with my Digital Camera which I am converting to MPEG2 in TMPGEnc for transfer onto DVD.
The problem is that when there is any rapid movement (mainly noticeable on panning) the edges of everything has a very noticeable distortion. The distortion is hard to explain, but looks like the edges have been 'combed' (ie. it looks like each alternating line is out of alignment.
I have tried changing various settings in TMPGEnc but have been unable to get rid of the distortion. Due to the appearance of the distortion I thought it might have something to do the interlacing setting, but changing it to non-interlaced didn;t have any effect either.
Sounds like you have DV AVI as a source. You need to set TMPGEnc up for BOTTOM FIELD FIRST although if you were using the WIZARD MODE it should have set that correctly but I have heard that the WIZARD MODE will screw that up from time to time.
Originally Posted by FulciLives
If I burn it to DVD, it does seem to be OK on TV, however I also want to edit the clips (in Premiere) and am worried that once I edit and render the clip the quality will downgrade even further and become unwatchable.
I guess the best idea is to give it a go and see what the result is.
Thanks for your help. -
DV AVI from a digital camcorder will always be true interlaced video.
Interlaced video will give you that "combed" effect on a computer monitor ... this is a normal thing. It does this because that is just how interlaced video looks on a progressive computer monitor.
It will look normal on a TV once you burn it to a DVD and play it back on a TV so don't worry about it.
Edges look jagged, and lines across the video.
By killerteengohan in forum DVD RippingReplies: 18Last Post: 29th Jul 2011, 13:18 -
Why does this x264 encode from DVD have these jagged edges?
By Obelik in forum DVD RippingReplies: 7Last Post: 17th Apr 2010, 00:59 -
Jagged edges on buttons
By motown01 in forum Authoring (DVD)Replies: 1Last Post: 21st Oct 2009, 11:40 -
Jagged edges upon PSD inserting in PPro
By Vially in forum EditingReplies: 0Last Post: 12th Sep 2008, 16:34 -
Procoder 2 - Jagged Edges
By pbar in forum Video ConversionReplies: 4Last Post: 24th May 2007, 09:32
