As the topic says, I need to batch append the same AVI to the end of 800 different AVI's.
I found programs to join videos, but I would have to change the first video every time, Does anyone know a program that will change the first video every time and then append the same 30 second ending onto each video?
Any help would be greatly appreciated.
Thanks!
Kevin
Have you tried virtualdub? It has some very good options. Might be worth it. Plus it has a batch option (job control).
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
If you got access to a Linux box, look at avimerge (part of the Transcode package).
I'm pretty sure tho, that, no matter what tool you use, if your 800 AVI's and the ending doesn't have exactly the same properties (audio and video codecs, frame size, frame rate, bitrate et c.) you're in for lots of trouble.
/Mats
script to append numbered .avi sequence via AviDemux?
By MilesAhead in forum Video ConversionReplies: 2Last Post: 13th Jan 2010, 00:24 -
Cannot append some AVI files in VirtualDub.
By StehpenRH in forum EditingReplies: 3Last Post: 8th Oct 2008, 04:51 -
Problem with Append AVI in VirtualDub - Audio of Sync - How Fix?
By Chakra in forum Newbie / General discussionsReplies: 3Last Post: 6th Aug 2008, 18:00 -
Batch processing .AVI
By R2 in forum Newbie / General discussionsReplies: 2Last Post: 12th Feb 2008, 20:34 -
Append the same AVI file on 70 different AVI files?
By Speed Demon in forum EditingReplies: 3Last Post: 15th Sep 2007, 04:55
