Hi, first of all thanx to everyone n specially baldrick for his guide on MKV to AVI. I've followed all the instructions but for some reason im having this prob with 1 of the 4 episode of my movie.
I'm going to try to give as much info as possible n explanation:
When I tried to save my mp3 (using lame3 or even MPEG-Layer 3), it wouldn't let me it would say: "Error initalizing audio stream decompression: the request conversation is not possible. check to make sure you have the required codec." So I didn't decompress it thinking that well it was already in a mp3 format, so I only demux the subtitle. so after the demux I saved it in avi and changed both (audio n video) four cc to DIV (since when I did put both avi n sub together it got n error message about the video decompression error message). Then I put both avi n sub together as specified by baldrick guide n everything went smoothly it decompress without the previous error message ( error decompressing video ..... error -100).
now my real problem is that this only one of the 4 avi movie not only is the sub not sync but the audio is not sync either to the video. problably by couple of secs or more. I saw that I have to sync the sub in Subtitle workshop (that was when i realised the audio was not sync too as the lips would move before the conversation). My guess is probably I have to decompress the audio but I cant since it gives me that error message.
below is the info about the audio n sub n video hopefully the picture will be print
Audio stream 1[0x0055,MPEG-1 layer3 (MP3)].ID [A-MPEG/L3].
Text stream 1.ID [S_TEXT/UTF8]
Have you tried virtualdub? Can virtualdub read mkv? If it can you can extract the audio to wav.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
No virtualdub cannot open MKV format, Have to use virtualdubmod.
Wander if I put in the right forum thought. ??? -
VDubMod's mkv support is out of date. mkvextract would be better. Althought VDubMod should have no problems with a mkv using VfW video and mp3 audio like that. Should simply be able to remux to avi ,no need for decoding/demuxing.
hi celtic_druid, thanx for the ans. I didn't know that it was old. Althought I do like it, anyway what do you mean by remux in vdualmod. How do I do that.? As I want to be able to keep the subtitle as my movie is japanese n the sub is english.
you lost me there
How can I do that?? with what program ?
my video is a MKV - four CC-XVID MPEG-4
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 14:10 -
MKV Codec for Realplayer?
By adrian2055 in forum Software PlayingReplies: 3Last Post: 27th Jul 2010, 08:03 -
whats best to convert MKV to other HD codec?
By snadge in forum Video ConversionReplies: 4Last Post: 3rd Jul 2009, 22:09 -
Searching for matroska/MKV Codec
By moviebuff2 in forum Newbie / General discussionsReplies: 2Last Post: 26th Dec 2007, 09:54
