When I rip a DVD and use TMPGEnc to encode it to SVCD the output file has a lot of background noise. I've tried using Toolame to encode the sound but it's the same :/.
Can anyone help me out plz?
I assume you are using dvd2avi to frameserve. If so test the wav file it creates and see if the noise is there or not. If not then at least we know for sure TMPGenc is the problem.
The problem is almost certainly because of TMPGenc's frequency changer. This has been known to do all kinds of things with audio. The solution is to either use dvd2avi to convert from 48kHz to 44100kHz or to use an external frequency changer from withing TMPGenc. ssrc (shibatch encoder) is regarded as one of the best tools for the job.
background noise in dvd (from .mov)
By nunsepofa in forum ffmpegX general discussionReplies: 6Last Post: 4th Mar 2012, 20:14 -
Dvd with background noise
By Pumkinhead in forum Newbie / General discussionsReplies: 3Last Post: 11th Nov 2010, 09:58 -
Background noise removal - Please help!
By maurof78 in forum AudioReplies: 2Last Post: 3rd Oct 2010, 09:24 -
Background Static Noise..
By Superstar24 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Nov 2008, 00:28 -
removing background noise
By pw29010 in forum EditingReplies: 2Last Post: 16th May 2007, 21:27
