    Dec 2005
    Australia
    I've read (I think it was even on this forum) that I could use WVW to fix out of sync files, so I downloaded it the other day to try it out.
    But when I open my avi file to the program, it gives me an error that "DivX(tm) MPEG-4" codec, and that the editor cannot find it's codec on my system..
    I usually use VLC player, so I downloaded FFDshow off DivX.com, 'cause it had all the codecs I needed...
    but after installing it, WVW still couldn't find the codecs needed..
    Is there a way to fix this? in that case..how?
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Isn't it an MPEG editor only ?
    If in doubt, Google it.
    Dec 2005
    Australia
    it says it supports avi as well..=\
    install the divx codec.
    but mpeg video wizard is mainly for mpeg editing...not for fixing divx syncing...or what are you doing? converting to dvd?? or?
  5. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I stand corrected.
    http://www.womble.com/support/FAQ03.html
    3. Can I import AVI files into MPEG Video Wizard?
    Yes, you can.
    In order to import an AVI file, the editor will need the help of an installed video/audio codec. Currently, the editor only recognizes VFW (Video For Window) drivers.
    Please also note that AVI is just a file name and like a big box which can contain different things --- compressed or uncompressed video and audio.
    Who would've thought their FAQ would hold the answers, eh ?
    Dec 2005
    Australia
    I want to fix an out of sync avi file.. a movie.. I've read that the program can be used for fixing out of sync mpeg's, so I though why not try..=P
