Hi all Im using windows xp/nero 5xxx/tmpeng 2xxx/smartripper 2.41/dvd2avi. Now when I burn using exactly what sefy's guide says I play on my dvd player the vcd I have authored and I get a choppy/stuttering vcd I have authored in pal, and ntsc using nero and ive tried nti cd maker neither work what am i doing wrong????
The mpeg plays 100% fine before burning in nero.
Please help im going crazy.
Help is Required!!!
Keep up the good work GuyZ excellent Site!!! -
Before you go crazy, can you tell me what did you do ? cause following a Guide to the "T" is not good, you need to use the guide as an Example! to guide you through.
I believe the reason you got choppy VCD is because you encoded a PAL or NTSC movie to a NTSC or PAL VCD, and that's why it is choppy.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
Conversion problem - Laggy (choppy) video
By yaang in forum Video ConversionReplies: 3Last Post: 4th Nov 2009, 12:36 -
WMP11 wont play some MKV files-problem (choppy audio output only)
By deejay.2001 in forum Software PlayingReplies: 4Last Post: 31st Jul 2009, 07:09 -
Can you solve my choppy video problem?
By imrealdumb in forum Newbie / General discussionsReplies: 2Last Post: 4th Jun 2009, 20:44 -
Help With Choppy DVD
By hgsouth in forum Authoring (DVD)Replies: 7Last Post: 12th Apr 2008, 23:18 -
Choppy Result
By darkdog in forum ffmpegX general discussionReplies: 1Last Post: 22nd Mar 2008, 22:32
