Hi, I have episodes I would like to burn onto one DVD. I have done this in the past with avi2dvd, but I would like to make a menu so you can select one of 13 episodes. I have tried using Diko, which I found here, and followed the link to how to use it. But for whatever reason, it doesn't end up being burned by DVD Decryptor (which i have installed and have used succesfully in the past). I have selected that option in the original program. Does anyone out there have an easy way to do this? It seems like it must be out there, but I have searched these guides high and low to no avail before I ended up posting this. Any help is much appreciated.
video converter & dvd burning with menu
By bobbiedville in forum Video ConversionReplies: 3Last Post: 20th Oct 2010, 03:00 -
DVD burning + menu from Avid MC...
By B-Twien Bytes in forum Authoring (DVD)Replies: 28Last Post: 28th May 2009, 05:24 -
Vista compatible disc authoring/burning software with sub menu options?
By wetcamelfood in forum Authoring (DVD)Replies: 7Last Post: 7th Jan 2009, 22:08 -
GUI for DVDAuthor burning iso to dvd player no menu audio
By opti280 in forum Authoring (DVD)Replies: 13Last Post: 8th May 2008, 21:11 -
Burning Multiple AVI's with Menu
By Candoo in forum Authoring (DVD)Replies: 12Last Post: 8th Jan 2008, 18:52
