I assume a dvd has 2 audio streams: cantonese and madarin. but the cantonese audio stream has another audio stream attached to it. how do i separate them, and what program could i use?
How do you mean, have another audio stream attached to it ?
Do you mean you hear two audio track at the same time ?
If so, does one come from one speaker, and the second from the other speaker ?
Or do they just talk over the top of one ?
If it is two voices form different channels (speakers) then demux the audio to wav, load it into an audio editor and copy the channel you want over the channel you don't. Save the results, re-encode and re-author.
Demuxing can be done with PGCDemux
Audio Editing can be done with Audacity
Encoding can be done with ffmpgegui
If the two voices are mixed on a single track, talking over the top of each other, then there is pretty much nothing you can do.Read my blog here.
oh, its 2 voices mixed on a single track. :/
thx for helping though.
Maybe this will help, but you'll have to read-up to
figure out how to do it!
The separation worked in their examples, although the
quality isn't perfect.
http://www.cnl.salk.edu/~tewon/Blind/blind_audio.html -
I have a similar problem in that I have RMVB files which I converted to AVI-DivX files using ffmpegX on the Macintosh. On the computer, I can choose which audio channel to playback along with with the movie.
When I record the movie as DivX disc (to playback on a commercial DVD player which supports DivX playback), I lose the ability to choose the left and right channels and the two audio tracks become one (played back one over the other). The DivX disc is recorded using Titanium Toast7.
Is there anything out there on the Mac platform which can help me in this?
Two Different Audio Streams In The same VTS.
By GangstaRap in forum Authoring (DVD)Replies: 7Last Post: 22nd Jan 2009, 10:00 -
DVD Audio Streams
By jeh in forum Newbie / General discussionsReplies: 6Last Post: 29th Jan 2008, 15:23 -
Video with 2 Audio Streams TO mpeg1 with 1 audio stream
By Xenogear900 in forum Newbie / General discussionsReplies: 1Last Post: 5th Aug 2007, 19:00 -
Dual Audio Streams
By BobafettBH in forum AudioReplies: 0Last Post: 9th Jul 2007, 16:02 -
Multiplex with two audio streams
By heretic754 in forum AudioReplies: 2Last Post: 1st Jun 2007, 23:44
