Hi I Have the cyberhome dvr 1600 dvd recorder and it does state on the website tht it is compatible with avi xvid and divx i am having problems playin avi's i have 2 on a data dvd that wont work just wondrin if any1 else has had the same problems.
Welcome to the forums.
I would check 'DVD Recorders' to the left for user comments on your model. <<<<<<
You might also want to check your manual or the Cyberhome site to see what their specifications are for Divx or Xvids.
It could be the Divx/Xvid format you are using is not compatible with the player.
Need help finding replacement for Cyberhome player
By canofhumdingers in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Mar 2012, 20:15 -
CyberHome DVD Recorder
By JRPAT in forum DVD & Blu-ray RecordersReplies: 1Last Post: 25th Sep 2008, 18:08 -
Cyberhome DVR1600ME2 firmware
By DogDoor in forum DVD & Blu-ray RecordersReplies: 2Last Post: 19th Jun 2008, 15:45 -
cyberhome 300s need a firmware update
By etrin in forum DVD & Blu-ray PlayersReplies: 10Last Post: 24th Dec 2007, 06:12 -
Looking for replacement for Cyberhome CH-DVD 300
By inmate1577 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 19th Dec 2007, 08:28
