hi, im trying to take 30 seconds of the same clip from a dvd (ill do the same for 5 dvd's)
1, original quality
2 compressed using 1 click copy as if it would be a dvd-r
3 use dvd builder to do its thing and compress it as if it would be a dvd-r
then take the 3 clips form the dvd (and the 4 other dvd's) totally 15 30secon clips and put it on a dvd-r with chapters so i can taker it to the shop and watch for 5 mins on each tv
why am i doing it
1, to find a good tv
2 to find a good tv for dvd-r's
3 to find out if all my other back-ups done with 1 click are rubis compared to dvd builder
4 to find out if there is big difference between orignal and nback-ups
i need a test dvd cos i dont want to be fidling around with changing loads of disks
it owuld be noce to have chapters and even txt on the screen telling me what clip im whating
i have absolitly no idea how to di this so please cna someone help me out
thanks
This should help a bit
http://www.digitalfaq.com/dvdguides/edit/editdvd/editdvd.htmWant my help? Ask here! (not via PM!)
that only helps if i am cutting like 30 mins out
really could use someone who knows exactly how to do what i am asking
thanks -
1)Smurf said that his link should help "a bit"...not be the definative answer.
2)You won't find "the definative answer" because what you wish to achieve is a lot of tedious work by anyone's video abilities. Taking a complete chapter of a DVD is no problem at all...taking anything under that is more like "editing". -
What you want is to first shrink the disc in all the various ways. Yes, make them all. Takes hours and days, good luck with that.
Next, extract clips from each disc, using guide I linked for you.
Edit them down to 30 seconds in something like Womble MPEG-VCR or VideoReDo.
Finally author them in something, probably TDA.
It's not hard, it just takes time.Want my help? Ask here! (not via PM!)
a chapter is fine, if i can cick next and be on the new clip iosts fine, i guess i could just swap disks but its sooooo much harder to compare that way
i think it would be fine to do a whole chapter, thats like 10-15 mins -
I don't see what the issue is. This is a simple project from a technical stand point. The only issue is the amount of time required, however I believe I could get something very close to what you are talking about assembled and ready in under 3 hours using existing chapter points, and 6 hours if extra editing is required.
In fact, using playlists in DVD Lab Pro could make this a very simple job.
Rip the chapters you need with DVD Shrink, demux them with PGCDemux, author with DVD Lab Pro, using play lists to produce different versions with different lengths or combinations. 3 hours would have this project completed.
If you had started this project when you first posted about it, you would be out looking at new TVs by now.Read my blog here.
making a good quality avi from ts, vob etc
By pooksahib in forum Video ConversionReplies: 8Last Post: 11th Sep 2011, 09:41 -
Need help making good DVD
By KLavoie in forum Authoring (DVD)Replies: 8Last Post: 13th Aug 2011, 16:27 -
Making a high quality dvd of tutorials
By jeff dachowski in forum Newbie / General discussionsReplies: 20Last Post: 16th Jul 2011, 10:06 -
Really struggling making a high quality MPG from dvd on hard drive
By Yarko1967 in forum DVD RippingReplies: 29Last Post: 15th Apr 2011, 10:39 -
Two DVD-9 videos on one DVD-5 disc with good quality?
By varied in forum Newbie / General discussionsReplies: 15Last Post: 28th Mar 2008, 21:15
