Hi there, I have a little problem with a DVD that I`m trying to backup, from a backup, is the cyclic redundancy problem, tried with DVD Decrypter and Clone DVD, same result, 85% done and then, the message.
I had that problem once or twice before, but with the DVD Decrypter the problem was solved, so I don`t know what else could I do to resolve this, any special suggestion?
Thanx in advance.
Well usually its a sign of a scratched disc. It could also be a arcoss sony protected dvd. Dvd Decrypter isn't updated anymore and I don't know if clonedvd can handle it.
Try dvdfabdecrypter. It might do the trick.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Thanks for the suggestions
DVDFabDecrypter : same result
IsoBuster : what I have to choose when it reads the part with the problem, between 3 options : omit, replace with zeros or something with dummies?
Cyclic redundancy check error
By Arch3type in forum ComputerReplies: 6Last Post: 16th Jan 2011, 01:32 -
How to correct this Cyclic Jitter ?
By zenzen1 in forum Newbie / General discussionsReplies: 3Last Post: 8th Aug 2009, 18:43 -
I/O Error (Cyclic Redundancy Check) - where does my problem lie?
By xxjustinukxx in forum Authoring (DVD)Replies: 3Last Post: 11th Apr 2008, 21:35 -
data redundancy?
By beer31 in forum ComputerReplies: 5Last Post: 23rd Aug 2007, 00:32 -
Cyclical redundancy, what is it?
By moviebuff2 in forum Newbie / General discussionsReplies: 6Last Post: 29th May 2007, 09:47
