I just unhooked my router from my computer and I now have my modem hooked directly into my PC, but I can't get online now? Any ideas why that would be, or how to fix this?
Results 1 to 9 of 9
What We Do In Life, Echoes In Eternity....
If this is a cable modem, unplug the power cord, wait 3-5 minutes, then plug it back in.
If DSL, make sure the PC is set to obtain IP address automatically, and/or check the addressing scheme. Router will most likely be on a different subnet than the modem. -
modems store MAC address of the device they are connected to and will not issue a new IP to the new device unless their memory is flushed. Power down as said above (5 secs is enough). If no connection call tech support. Your IP may be missing/delayed. No need to get more in depth here as this goes beyond the scope of this forum.
How is modem configured? It sounds like modem is in bridge mode, and it'll need to be reconfigured if that's the case. Call support for either ISP or modem for instructions if you don't already have instructions.
All set fixed it, just needed to unplug modem and restart comp.
What We Do In Life, Echoes In Eternity.... -
You could have also done it by launching a command prompt and entering ipconfig /release and ipconfig /renew.
Believing yourself to be secure only takes one cracker to dispel your belief. -
Ditto. Release /Renew will most definitely NOT work, for the reasons stated. At least on a cable modem.
DSL, it depends. -
Release/renew does work on a Windows 98 system with wireless adapter I have, but I don't know about other OSs or hardware.
Router for USB Cell Modem
By Poppa_Meth in forum ComputerReplies: 3Last Post: 11th Jun 2009, 19:02 -
Which modem router to get?
By Tbag in forum ComputerReplies: 3Last Post: 1st Jun 2008, 16:54 -
when WAN is connected to the router the network speed drops to half...?
By stars in forum ComputerReplies: 18Last Post: 19th Feb 2008, 11:44 -
using modem router whilst shut down
By Tbag in forum ComputerReplies: 2Last Post: 28th Sep 2007, 16:14 -
DSL modem/router forwardports?
By mvp in forum Newbie / General discussionsReplies: 5Last Post: 27th Jul 2007, 14:52
