Hi
Has anyone ever successfully created thumbnail motion menu "frames" in Tsunami DvD?
I can only create a white box around the motion menu window. Can anyone help?
I do them all the time - what's the problem?
What I do is to select the length of time to display the motion menu & specify the entry point for the various video tracks (clips) I wish to display, and TDA does the rest.
Hope this helps!
Cheers!
TTWC"I've got a present for ya!" - TTWC -
Hi
I am referring to creating your own "PSD" files which serve as a surround "Picture frame" for motion menus. TDA allows you to import your own designs. I can get the windows area where the motion menu occurs, but the surrounding graphics always turn up as a white square frame. I want to create a window opening in the shape of a heart, and the surrounding frame from roses etc.
has anyone done this procedure?
Please help -
I don't know about the latest version, but certainly from its predecessor TMPGEnc DVD Author V1.6 back you could not import custom frames. thumbnail and background images, yes, but not the frame decorations themselves. Has this changed with the latest version ?
If in doubt, Google it. -
Hi
yes, this is now a new feature. A great one if I could get it to work.
Has anyone done this?
No sound in VLC, MPC, or Tsunami DVD Author
By ibzomie in forum Newbie / General discussionsReplies: 0Last Post: 7th Dec 2009, 14:56 -
Successfully Burned 4.99 GB onto ASDA Branded DVD+R Disc
By Mixtrixx in forum MediaReplies: 5Last Post: 29th Aug 2009, 09:10 -
Dual Layer DVD successfully burned, but won't play on a DVD player Help Plz
By Ruudboy in forum Newbie / General discussionsReplies: 9Last Post: 13th Dec 2008, 02:09 -
Animated thumbnail (playing thumbnail) in DVD menu??
By blizzery in forum Authoring (DVD)Replies: 13Last Post: 9th Nov 2007, 01:46 -
Tsunami-Mpeg DVD Author Pro Transcoder Question
By RKelly in forum Authoring (DVD)Replies: 6Last Post: 16th Aug 2007, 21:51
