Is one better than the other for burning test discs to see if they play properly?
Thanks,
BGC
Try both.
See if they both play on your stand alone DVD player. It really shouldn't make a difference. If both play on it, then use whichever one you have available at the moment.
Personally, I haven't had problems with either one. -
Do the +RW allow you to change the booktype like the +R do? I'm not sure where the manual for my standalone is but I think the only recordable mentioned was -R. I've made a few tests on -R and they play without problem, I haven't tried anything else as of yet.
Thanks,
BGC -
DVD-RW works less of the time than DVD+RW (opposite of how DVD-R works more than DVD+R), depends on your player.
DVD-lab burns DVD-Video, Ashampoo and ImgBurn fail... Why?
By nbarzgar in forum Authoring (DVD)Replies: 9Last Post: 1st May 2011, 14:27 -
Best avi to dvd software that burns
By mol3000 in forum Video ConversionReplies: 1Last Post: 19th Aug 2010, 00:19 -
DVD burner only burns DVD-RW now and firmware problem.
By yocahu in forum DVD & Blu-ray WritersReplies: 2Last Post: 14th Mar 2010, 22:23 -
Keep getting bad DVD burns after OS reinstall
By brassplyer in forum ComputerReplies: 18Last Post: 20th Sep 2009, 02:12 -
Laptop DVD Burner suddenly only burns small portion of DVD
By hydrurga in forum DVD & Blu-ray WritersReplies: 9Last Post: 13th Feb 2008, 04:39
