Can I overwrite previous versions with new updates?
I've noticed that if I add assets from two different locations, they're treated as separate movies. So I make sure my .avi files are in the same location, and add them together.
Is it possible to add assets from two different folders and still have them combined into the same movie?
Thanks so much for your help.
See http://software.badgerit.com/SVCD2DVD/DemoMovies/ManualLayout.htm for another example.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Thanks so much for your prompt reply. I found the tutorial you linked quite helpful-- I hadn't realized that Autofit was recommended for all .avi's. I'd assumed it was intended only for when the capacity on the DVD was exceeded.
Newbie bluetooth questions
By videohalp in forum Newbie / General discussionsReplies: 6Last Post: 28th Dec 2011, 04:37 -
couple newbie questions - DVD to MKV and watch on WDTV
By timmyinnis in forum Newbie / General discussionsReplies: 7Last Post: 26th Apr 2010, 03:14 -
Newbie questions about HD camcorder etc!
By n33712 in forum Newbie / General discussionsReplies: 10Last Post: 4th Mar 2009, 14:16 -
Newbie Questions DVD to ????
By swezey in forum Newbie / General discussionsReplies: 10Last Post: 25th Dec 2008, 09:19 -
Some newbie questions about sirius
By janeydoll in forum AudioReplies: 9Last Post: 10th Jun 2008, 01:19
