I use a Mac (OSX 10.4.5) and something called Mac the Ripper to rip DVDs, remove CSS encryption, de-Macrovision, etc. (I also use DVD2oneX if needed and Toast). Mac the Ripper works beautifully but requires the source DVD to be in the drive in order to extract.
A while back I had a couple of DVDs whose contents were copied to my hard drive without removing any copy-protection. As a result I can't view them or burn them. I no longer have the actual DVDs so the software I have is useless.
Can anyone recommend something I can use to decrypt these files so I can burn them and get them off my drive? Again it needs to be Mac compatible. Thanks.
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator mats.hogberg
Closed Thread
If you don't have the original DVD, all your should be considered with, is how to remove the copies from your HDD. (or anywhere else)
/Mats
Soniq QMD80B Portable region coding firmware update
By twiztid in forum DVD & Blu-ray PlayersReplies: 1Last Post: 14th Aug 2010, 04:44 -
Region coding on burned disks.
By sambat in forum Authoring (DVD)Replies: 6Last Post: 14th May 2010, 17:59 -
Cannot watch DVD on my DVD player after removing region restrictions
By robertin75 in forum DVD RippingReplies: 5Last Post: 17th Apr 2010, 11:27 -
BluRay Region Coding Announced - Japan & US Same Region
By GullyFoyle in forum Latest Video NewsReplies: 57Last Post: 18th Dec 2008, 16:55 -
DVD Region Coding
By jasej in forum Authoring (DVD)Replies: 5Last Post: 27th Jul 2007, 08:59
