    Mar 2006
    Alright, sorry if that wasn't a very clear title...or if this can be found somewhere on the site. I looked everywhere.
    Here's the deal - I have a picture (JPEG to be exact) - What I want to create is a movie of a line appearing from place to place. Like a movie of a line being drawn from point A to point B.
    I think this might be possible in Photoshop - I figured out how to make a path and have it drawn...but I want the movie to show the line being drawn - as if people are moving! I guess I could make an animation in Photoshop, drawing little segments of the line in each frame - but this seems tedious and I would think look choppy...?
    That's the point of it all - I want to show movement on a map.
    Thanks for any and all help!
    Northern Territory
    Yes Mate
    Quite Easy if you are using a video editor program like adobe prem pro or similar.
    Just imagine your map as the main image on screen, & then you have a layer (your photoshop red lined map from A - B.)(same map plus a line) Simply just use a page transition (like a left to right sweep) and your line magically draws itself across the page.
    Same as moving from one scene to another in a movie. You notice that because they are usually 2 different scenes.
    Cheers from the Outback
  3. Member daamon's Avatar
    Melbourne, Oz
    Hi constantmotion,
    Welcome to the forums.
    Your requirement is discussed extensively here: https://forum.videohelp.com/viewtopic.php?t=279213
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
