Results 1 to 11 of 11
    Mar 2006
    Ok, just joined here.. I have a problem that is really gettin me frustrated, cannot seem to get around it...
    I have a 4:30:00 long mpeg2 .mpg file, specs are 352x240 at 29.97fps, 1923kbps, 2ch audio 48k sample and 128k bitrate. Total size is 4.21gb
    When I try to author this mpg onto a dvd I get the full video and audio into the VOBs but the IFO only indexes 2:15:00 of it. VOBs play fine on the computer, but will not go past 2:15 on a console...
    HALLLLPPPPPPP!!
    wtf is wrong? I have used 3-4 different author proggies, and all do the same.
    Thanks for any advice...
    -jerry
  2. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    Which 3-4 author programs have you tried?
    Buy My Books
    Mar 2006
    umm...
    dvdauthor freeware
    dvd-lab (sucks)
    dvd composer
    all found here...
    also tried nero vision, but it crashed it real good every time.. dunno what was goin on there.. it always bit it on the transcode..
    -j
  4. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    Unfortunately I haven't used any of those, but dvdauthor is supposed to be pretty good. Is it possible there's an error in the source file? Try opening the source file in VirtualDub-MPEG2 and scan for errors.
    Buy My Books
    Mar 2006
    can you recommend any author package?
    im doin a scan now... (mpeg was produced from a mpg-1 capture thru tmpeg, so its prolly ok)
    tnx
    -j
    Oct 2005
    666th portal
    could it be that it was joined together from more than one part? if so than gop timecodes are messed up. dvd-lab can fix it, but it sucks..... and i don't know what else will.
    Mar 2006
    hmm... yes it was joined from 3 different cuts.. but there was no joint at the 2:15 problem area.
    kinda strange that its exactly half the length where it bombs...
    i`ll give dvd-lab another go and see what happens.. this thing is p*ssin me off...
    wouldnt a complete conversion from mpg1 to mpg2 re-align that stuff? hmm i duno im no expert here
    -j
  8. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    in dvdlab pro under tools try 'rewrite gop timecodes" before authoring and see if it helps. use a copy of the file as the changes are permenent.
    Mar 2006
    ok i nabbed dvd-lab pro (gotta love trialware)
    did the GOP reindex, did a test on it first, it went thru first but the progress bar went up to 2:25 then it went blank after that. Did a full reindex, then tried a test again, and it did the same thing.... GOPs displayed fine on the preview window before I did anything tho.. who know lol..
    im makin some menus n crap now, guess i`ll let it run overnite and see what happens.. sigh..
    tnx d00ds
    -j
    Mar 2006
    OMFG i think it worked
    I dont see any sign of the 2:15 problem anymore, but havent burned it off for the final test (console)
    well its burnin as I type... we`ll see.. thanks aedipuss!
    -j
    Mar 2006
    welp it worked...
    phew glad to get that done with...
    /sits back and has a beer
    thanks all
    -j
