  1. I am looking for an application which is able to convert audio anything to anything, or at least the closest possible: the more options the better, any advise?
  2. Member olyteddy's Avatar
    Dec 2005
    Try to find an old program called 'Streambox Ripper'. Or get a bunch of plug-ins and use WinAmp.
    USA
    BeSweet does a lot. You probably want a GUI with it, BeSweetGUI or BeLight. MediaCoder is another audio encoder that is very versatile. Those are about as close to all-in-one encoders as I know of.
    Dec 2004
    Australia
    dbPowerAmp. Has plugins for just about everything.
    May 2003
    Mission Viejo, CA
    I second the vote for dbPowerAmp , it does it all. Try the .wma at 192k 2 pass vbr - it's as good or better than 256k anything else.
  6. Thank you guys i will give this program a try!
    Dec 2004
    Australia
    I bet you couldn't ABX a ~192k VBR lame encoded mp3, a ~192k vorbis encode or lc aac encode from the source so I can see no reason to use WMA.
