I have tried over and over again to install avisynth. It downloads but when I go to install, it starts then stops and gives me a message: You must have administrator rights to install Avisyth!\r\n\r\n(Could not write to registry).
I do have adminitrator rights, never had a problem before. Windows firewall is off. What is the problem? Any ideas.![]()
I love children, girl children... about 16-40
W.C. Fields -
Yes, the problem seems to be with an AVISynth 2.5 directory being on the drive. Delete this directory and it should install (just remember to save your \PLUGINS directory somewhere first).
Or, do what I did, and install 2.54, then install the latest.ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Avisyth 2.54 installed OK, but newer versions still give me the administrator rights message. Tried Rebuilder with Avi 2.5 but now get this message when I go to Encode:
Avisynth open failure: Script error: There is no function named "Mpeg to source" (G:\VIDEOTEMP\D2VAVS\V01000000001001.avs, line5)
Any ideas, or do you know of a troubleshooting guide?I love children, girl children... about 16-40
W.C. Fields -
There's something wrong with the command in line 5 of your avs.
Post the script and we should be able to spot what's wrong."Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
This is the first time I'm trying Rebuilder and Avisynth, so please bear with me. Thanks. Where would I find this avs file line 5? This is what I get when I open the file V01000000001001.avs:
# AVS File Created by DVD Rebuilder
# VOBID:01, CELLID:01
mpeg2source("G:\VIDEO TEMP\D2VAVS\V01.D2V")
trim(0,4394)
ConvertToYV12()I love children, girl children... about 16-40
W.C. Fields -
You did good. The script is the text that's in the avs file.
If I recall correctly mpeg2source requires a plugin, and it looks like your updated AviSynth can't find it. So you either have to make sure the plugin is in the correct location, or you have to expressly call the plugin. I don't use Rebuilder but it appears that Rebuilder assumes the plugin is in the correct location (which makes sense since it wouldn't know how to find elsewhere).
I'm drawing a blank right now on where the plugins need to be, I think it's
"C:\Program Files\AviSynth\Plugins"
but I could be wrong. Maybe someone else can improve my memory."Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
Known problem with xp sp2 with some installations
see
http://forum.doom9.org/showthread.php?t=109477
64-Bit AVISynth wont install
By killerteengohan in forum EditingReplies: 1Last Post: 10th Mar 2012, 22:55 -
Unable to install avisynth: Error opening file for writing
By ximon in forum Newbie / General discussionsReplies: 3Last Post: 12th Dec 2011, 17:52 -
can't install Avisynth due to the devil.dll
By cemman in forum Newbie / General discussionsReplies: 6Last Post: 2nd Aug 2009, 05:18 -
Linux won't install
By lordsmurf in forum LinuxReplies: 1Last Post: 13th Aug 2007, 10:59 -
How to install plugins for Avisynth?
By 1gnition in forum Capturing and VCRReplies: 4Last Post: 19th May 2007, 19:06
