I have problem with size of subtitle in my movie dvd, It so small i can't read it
So i want to change size of it.
1.Use OCR program(subrip)
I have a problem again with OCR program(subrip) can't rip percectly my language subtitle(Thai) so i must type all the words again.![]()
2.Demux to *.sup (bitmap) I don't know any program can change size of subtitle ? (only size,not edit word,color ...)
Have any way to change just size of subtitle without using OCR program?
Subs are only bitmaps. You could probably extract the bitmaps and use some image editing program to resize them, but that would take longer than extracting, changing the font size, then reauthoring the thing.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Thanks SLK001
Now i use the latest version of subrip ,Problem is my thai text (Have both upper & below text)I see that your language is Thai. Check out the latest Subrip version - it handles UNICODE characters now. This may or may not solve your problem.
i can't type both upper or below text without type the main text before So Subrip can't rip correct both upper and below text.
Finally OCR program can't rip my thai subtitle correctly. -
All an OCR program does is map patterns to a particular object (here it is font bitmaps to font characters). YOU provide the particular object (RE: font character) based on the bitmap patterns. I don't know what you mean by "upper & below text". Do you mean "upper & lower case" characters? Or, does the Thai written language have both upper & below parts of a character. There are Windows UNICODE fonts for Thai (Angsana New is one) that I can see, but I really can't understand what problem you are having.
Can't change subtitle size on avi file
By jlulu1979 in forum MacReplies: 0Last Post: 11th Aug 2011, 19:41 -
Subtitle Edit question about OCR using a french dictionary
By jesant100 in forum SubtitleReplies: 1Last Post: 9th Jul 2011, 13:25 -
Burn subtitle and change font size
By Nazarenojr in forum ffmpegX general discussionReplies: 8Last Post: 14th Mar 2011, 05:25 -
How to change font size in a .sub subtitle file?
By nonexistent_entity in forum SubtitleReplies: 3Last Post: 15th Jun 2010, 15:36 -
How to change srt Subtitle style and font size in MEGUI ?
By DARIFBS in forum SubtitleReplies: 4Last Post: 12th May 2010, 15:19
