Hi there!
I want to add support for CCE on my next release of SynthEditor but, as many of you may already know, there are many different versions on the "market" or, maybe it's better this way, many different ECL files format.
the point is... it's a lot of trouble to enable all the versions at the same time for two main reasons... 1st It will take longer before I can release it... 2nd It's a little hard to avoid bugs (it will be better if I work version by version).
So... what I want/need to know is which is the most used Version... the elected one will be the first I'll add the support.
I hope I din'd forgot any of the different versions
note: The options on the pool are related to the different ECL files format - as you can see... a lot of work needed
Thanks in advance for your cooperation,
Rockas
My oppinions may change, but not the fact that I am right!
www.rockassoftware.pt.vu
DAudioK => https://forum.videohelp.com/viewtopic.php?t=306886
DVD Rebuilder
http://dvd-rb.dvd2go.org
http://www.jdobbs.com -
Yes... I voted for CCE 2.50... I bought it some years ago and now i just don't want to spend more money with some other cool FREE encoders out there
By the way... if you want to suggest another commercial Encoder feel free to submit it on this thread.
thank you.My oppinions may change, but not the fact that I am right!
DVD Rebuilder
CCE Basic for me. I bought it originally to use with DVD-RB Pro. It's now my encoder of choice. Thought, I still occasionaly use TMPGEnc Plus.
Hi folks,
Rockas many thanks for your great software DVD Rebuilder. It's aweosome. And I am sure your new creation will be even better. You are the guy! And by the way I use CCE SP 2.70.02.06 trial. Thank you again.
See you later,
Aeolis
P.S.: Keep the good job. Grande amigo continue firme trabalhando, pois seus programas são incríveis. Achei que um elogio em nossa língua mãe faria bem a você. -
@Aeolis
Thanks for your kind words but... DVD Rebuilder is not my creation... jdobbs is... I just help him in some minor aspects... but I think I can Thank you in his name... he is a great guy and he deserves all the good things in the world and all the nice words people can give him.My oppinions may change, but not the fact that I am right!
DVD Rebuilder
Mac version of VLC is less functional than the Windows and Linux version
By HitTheRoad in forum MacReplies: 12Last Post: 30th Oct 2011, 03:48 -
SUPER version 39 is broken - reinstall older version?
By castalla in forum Video ConversionReplies: 7Last Post: 3rd Nov 2010, 18:20 -
Problem DVD Rebuilder Pro: Is not a ECL for CCE SP Trial Version
By Talayero in forum DVD RippingReplies: 2Last Post: 30th May 2008, 13:25 -
Is the 'academic version' different from the commercial version of Vegas 8?
By jbigfoot in forum Newbie / General discussionsReplies: 2Last Post: 16th Apr 2008, 00:19 -
where to download old version of dvd fab??? error in new version
By willhenderson in forum Newbie / General discussionsReplies: 1Last Post: 1st Dec 2007, 16:00
