Can someone tell me is it better to use a dv cable to record videos on this machine or could i use the s video input instead.I dont have a dv cable but my jvc camcorder has a s video connection so im wondering which is better.
If you are outputting from your camcorder and it has DV out, definitely use that. The DV video is downgraded to convert to S-video.
Is the quality downgraded by much.Are the dv cables from my jvc camcorder to the pioneer recorder common.Where can i buy them and are there different qualites of cable.
I assume that you need a 4 pin to 4 pin 1394 cable.
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001...oductId=222631 -
Yes it is a four pin cable,are these cables called firewire 1394 Ieee cables .
In the case of the 533H, it will not make much difference. Gshelley61 did captures from DV and s-video input for a test on this thread with the 533H,
https://forum.videohelp.com/viewtopic.php?t=279460
Regrettably the 533H turns in a subpar performance from DV input. -
One of the nice things about the DV capture is that the Pioneer automatically places a chapter marker at each time code break (such as when you stopped or paused your recording). One nice thing about capturing via the S-video is you can use the Pioneer's custom video settings and you also can capture the date/time display from the tape (if you want that).
Q3 camcorder audio level in recording is lousy
By abrand88 in forum Newbie / General discussionsReplies: 1Last Post: 23rd Apr 2010, 13:08 -
Pioneer 533 DVD-R Burning Problem/Question
By tcfrerich in forum DVD & Blu-ray RecordersReplies: 27Last Post: 23rd Oct 2009, 13:03 -
Sony Camcorder to DVD Recording
By Techguy77 in forum Capturing and VCRReplies: 1Last Post: 25th Nov 2008, 13:56 -
No picture with Firewire connection to Pioneer 533 h
By Knightmessenger in forum DVD & Blu-ray RecordersReplies: 2Last Post: 17th Aug 2008, 16:10 -
Pioneer DVR 533 Problem -
By chris_james in forum DVD & Blu-ray RecordersReplies: 4Last Post: 17th Aug 2007, 02:59
