Hi - my problems this.. I have a Vcd movie (copy) and i want to reproduce it and as far as I can tell, nero will only burn a vcd if it is in mpeg format first. So, after scouring this website i downloaded vcdgear as this seems to be the best .dat to mpeg converter out there right? Well, once the .dat file had been converted to mpeg windows media player wont play it! I get the following error : "no combination of filters could be found to render the stream" I'm at a total loss, i tried to fix the mpeg with mpeg corrector but with the same problem??? could someone please help me. thank you kindly. By the way - my reason for wanting to re-copy the vcd is that it wont play on my DVD (LG 4210) unlike other vcd's i have, can you explain that one to me too? thanks...
Make an image of the offending VCD... (Clone CD/CDRWIN - etc. etc.) - Use VCD Gear to rip from the Cue/Bin to Mpeg.... Sorted
Hmm - tnx for the reply Kv5 - thing is, if you could go through the details for me please
What does making an image entail and do i need the clone CD software? Forgive my ignorancetnx.
...I have gotten hold of cdrwin - if anybody could explain to me how to make an image of the vcd using this software i'd be grateful.
VCD Karaoke (MPEG DAT file)- removing the vocals
By tsrusa2002 in forum Video ConversionReplies: 12Last Post: 22nd May 2011, 02:51 -
DAT to MPEG 1
By MI6 in forum Video ConversionReplies: 14Last Post: 8th Feb 2009, 15:01 -
convert VCD.DAT/MPEG to RMVb with dual channel audio
By newbievideohelp in forum Video ConversionReplies: 15Last Post: 6th Nov 2008, 23:42 -
How to corp a dat or mpeg file to mpeg
By onlyrasel in forum VCDEasy GeneralReplies: 1Last Post: 26th Sep 2008, 23:18 -
dat to mpeg - no sound
By goshz in forum Newbie / General discussionsReplies: 9Last Post: 22nd Jun 2007, 04:24
