Is it possible to remove references to deleted audio streams from a re-authored DVD, so they won't show up and be selected when pressing the remore control audio button during menu or main movie playback?
I would try DVD Shrink. If the audio references are there, even if empty, it might show them up. Make sure they are unticked and write the results back to the HDD and test play before burning.
Otherwise tools such as IFOEdit or PGCEdit might be worth a try. They are more complex because they get into the guts of the DVD structure.Read my blog here.
DVD Shrink works, the only "problem" is that I need to recode again. I suspect that PGCEdit works faster, but the procedure should be more complicated. Otherwise, could anyone advice how can I use it?
You shouldn't have to transcode again. Make sure that compression is set to no compression. Unclick the audio tracks you don't want and hit backup. It "write" out the entire DVD again minus the deslected audio tracks.Originally Posted by kyrcy
Mainboard cap replacement service references
By ranchhand in forum ComputerReplies: 6Last Post: 14th Jan 2012, 13:31 -
How can I remove subtitle streams from an m4v/mpeg4 video?
By extent in forum SubtitleReplies: 2Last Post: 18th Dec 2011, 17:39 -
Mini How-To: Edit Transport Streams to Remove Commercials
By Soopafresh in forum DVB / IPTVReplies: 4Last Post: 6th Aug 2009, 08:15 -
Video with 2 Audio Streams TO mpeg1 with 1 audio stream
By Xenogear900 in forum Newbie / General discussionsReplies: 1Last Post: 5th Aug 2007, 20:00
