Is there a video editor that can open mp4 files? i tried virualdub but it doesn't suport that file type. I just wanna cut out the intro and ending
you can do basic splitting and joining with yamb.
if you want to add filters and such you can use avisynth and then open in virtualdub. -
AVIDemux. Works ok for AVC or MPEG-4 at least. Not tried vorbis or anything else using private streams. But then again if you store stuff as private streams, you can't really expect it to be generally supported.
You need a 2.2branch build for the mp4 support to. But yeah, for simple cutting yamb/mp4box is fine.
easiest free mp4 editor
By angryassdrummer in forum Video ConversionReplies: 2Last Post: 5th Apr 2011, 04:38 -
Looking for a really light weight HD mp4 editor?
By The village idiot in forum EditingReplies: 6Last Post: 29th Mar 2010, 04:13 -
MP4\H.264 Video Editor
By Threshold in forum Newbie / General discussionsReplies: 3Last Post: 16th Feb 2010, 14:56 -
Joiner / Editor for H.264 AVC MP4 files
By nickb23 in forum EditingReplies: 8Last Post: 7th Aug 2009, 06:56 -
MP4 (PSP) EDITOR help
By efiste2 in forum EditingReplies: 6Last Post: 29th Jun 2007, 14:54
