I would like to convert some media I have (in various formats) to either Divx or maybe using Nero recode.
As these other clips are of various bit rates, when I convert them, what settings should I use to ensure that I maintain video quality. (File size it not too important to me at this time.)
Is it just a case of ensuring that the new video bit rate is the same as the old one?
Any help would be much appreciated.
T.I.A.
Red
No. Source bitrate has no connection with what bitrate to encode to.
Every reencode will introduce a quality drop. The higher bitrate you encode to, the closer to the source quality you'll get.
/Mats -
Hi Mats,
So I guess when re-encoding it will always be a trade off between file size and quality.
I'll have to do a bit more reading.
Anyway, thanks for the help.
Cheers
Red -
Originally Posted by rede
/Mats -
Since you don't need a specific file size use a constant quality encoding mode. Pick the quality you want and the encoder will use however many bits is required for each frame to get that quality. Divx calls this "quality based" encoding where you set a "fixed quantizer". Xvid calls it "single pass" with a "target quantizer". Some MPEG encoders have constant quality modes too -- TMPGEnc Plus for example.
The higher the quantizer the worse the quality and the smaller the file. Try using quantizer values of 2 or 3 as a starting point. At 2 the output will be nearly identical to the input. At 3 there will be a little macroblocking if you examine enlarged still frames but you won't notice them at normal playback speeds.
Best quality DVD output software for maintaining photo quality
By P_Erickson in forum Newbie / General discussionsReplies: 20Last Post: 21st Apr 2012, 22:30 -
Combining clips of varying bitrates, but maintaining quality?
By Grunberg in forum EditingReplies: 7Last Post: 22nd Jun 2011, 20:38 -
Maintaining AVCHDs sharpness in other formats
By danielbb in forum Video ConversionReplies: 3Last Post: 2nd Sep 2010, 16:50 -
Maintaining DVD Quality
By rbxbots in forum Newbie / General discussionsReplies: 2Last Post: 24th Mar 2010, 10:48 -
Maintaining quality from Flip Video to DVD
By mk4kc5cmc4@gmail.com in forum Newbie / General discussionsReplies: 5Last Post: 8th Mar 2010, 20:37
