hi guys, ive heard alot of talk about dvd builder being the next stage in copying a dvd
is it really gona make a huge difference, if anyone has compared the two on a nice big screen please tell
thanks
Huge difference, in many cases. Mostly for tv shows, not so much on short 2-hour movies.
yes it does make a big difference with large screen televisions. i played my CHICKEN LITTLE & MEMOIRS OF A GEISHA backed up copy i made with dvd rebuilder pro on my friends SONY 55 inch DLP set. whoas! my friend was stunned with the good quality of a backed up copy using dvd rebuilder pro.Originally Posted by slimpickins
Just Curious....How would it make it any better than whats already on the original disc?
You won't make it better than the original. You only need an application like DVD Rebuilder Pro if you are backing up to a disc that is smaller than the size of the film. Then you need to re-encode or compress it to make it smaller. There are many tools to do this, using different techniques. And not all tools and techniques are equal in quality.
The aim isn't to improve on the original, but to preserve as close to the original quality as possible when reducing the size of the film for backup.
The best quality is obtained by backing up the original to a DL disc (assuming the original is DL) so no re-encoding is required.Read my blog here.
What guns1inger said.Originally Posted by videopoo
When you go from 7-8GB down to 4.37GB, you will ALWAYS lose quality. The aim is to minimise the quality loss as much as possible. -
When I first started using DVDRebuilder with CCE I did an experiment with LOTR. Backed up one with DVDRebuilder/CCE and the other one with DVDShrink. There was very noticible difference! The one with DVDShrink you could see pixilazation around areas of darknes and movement, and it was a bit washed out looking.
The disk created with DVDRebuilder/CCE was much better looking. no pixilization. The only difference I could see from the original was the colors not being as vibrant. But still look really good.
These were tested on my brothers 50" Sony Rear Projection LCD TV. In a DVD Player with HD up convertion. -
edit -- wrong movie i was thinking of
Making BD Rebuilder work on a Mac
By Spoffo in forum Blu-ray RippingReplies: 0Last Post: 10th Mar 2011, 04:27 -
Hardcode Subs in DVD Rebuilder??....Or something that will work???
By mariachidude in forum DVD RippingReplies: 1Last Post: 26th Feb 2011, 14:48 -
Does BD-Rebuilder Full Disc mode work?
By ronorkis in forum Blu-ray RippingReplies: 22Last Post: 1st Sep 2009, 05:12 -
DVD in BD Rebuilder!!!
By fjmr in forum Blu-ray RippingReplies: 3Last Post: 18th Aug 2009, 10:22 -
dvd rebuilder
By dvd1304 in forum Newbie / General discussionsReplies: 2Last Post: 20th Jul 2009, 12:31
