  1. I bought Pinnacle Studio to do basic movie creation using my old 8mm video camera. It came with a DC10 mJPEG codec video card.
    Later I purchased a cheap TV Tuner card that also allowed me to capture video.
    Today, I have one simple desire...and I can't seem to get it done without jumping through a bazillion hoops: I WANT TO CAPTURE MUSIC VIDEOS from VH1 Classic.
    Thats it, thats all
    IF: I go from svideo out into the SVIDEO IN of my DC10 card, I get nice high quality captures.
    These are created as mjpeg AVI files. media Player classic can play them, but TMPGENC cannot open them. So I can't convert to mpeg or mpeg 2.
    FIRST I have to open the file in VirtualDub Pro.....I have to then convert that file to a raw avi file..so a 3 minute music video that takes up 600megs in mjpeg now takes up 5 gigabytes. THEN I have to use TMPGENC to conver that raw AVI file into an MPEG of my choosing.
    All in all....its a huge colossal pain in the ass.
    OH..and before someone asks, OUTPUTTING to Mpeg2 via Pinancle Studio 7 produces a fairly lousy MPEG2 file.
    SO...I said "what about the svideo of the Capture Card". Well, its crap. It gives me visible video distortion. Basically, unusable.
    SO: I am left with the following questions: IS there a way for TMPGENC to read the mjpeg AVI files created by the DC10 capture card?
    IF NOT...what would be a better way of doing this...if I chuck the DC10 card, and I chuck the cheap TV Tuner card...what do I buy that is relatively cheap?
    Do i buy something that encodes directly to mpeg2 on the fly? (my PC is a 2.2ghz P4).
    I tried to use iuVCR as my capture program but all it does is lock everything up on my box, so I keep going back to using Pinnacle Studio to do the captures.
    Can someone help me out of this mess without me having to spend more than $100 bucks on new hardware? $100 bucks is my upper limit for what I'm trying to do.
    PS: I'd still probably use the basic video editing properties of Studio 7, but is there an advantage to buying one of the new STUDIO packages that comes with a capture card and video studio 10?? Or am I just going back to where I am now with the DC10..are the files unreadable with other software...??
    Help? Thanks!
    USA
    TMPGEnc should read that format. Have you tried this:
    If you have problem open DV video, DC30+,MJPEG captured video or any AVI VFW
    Then try to change the settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the AVI VFW and increase the priority to 2 and try reopen the video.
    If all else fails, you could try a encoder program like SUPER. It handles most formats.
    I'm not sure if the latest version of Gspot (2.52) can read it, but you could post a screenshot from Gspot and someone may see the problem there.
  3. Try Huffy for the Codec, also Frameserve from Vdub to the encoder, no need to create the huge AVI.
  4. Buy a new mpeg2 encoder card. Some people like the haup pvr150 but I cannot vouch for/against it.
    The electronic components of the power part adopted a lot of Rubycons.
