I am having difficulty in adding subtitles to an AVI movie. I have all the files in the same folder : .AVI, .idx, .sub, .subs.sfv. In filters menu I select load subs. Preview shows subtitles ok. At the end of encoding I always get error message
"ERR: Couldn't load file /user/Desktop/title/title.sub. "
I have tried the old binaries to no effect.
You are probably not using text-based .sub subtitles, but image-based VOBSUB subtitles. They come in a pair of .idx and .sub files. If you load the .idx file, the "Play" button will allow to watch the movie with subtitles. However, and unfortunately, ffmpegX AVI encoding does not support burning of VOBSUB subtitles. Probably, only "DVD mpeg2enc" with the option "Decode with mplayer" enabled will allow to burn them.
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
Cant Play / Load A RAW DV file "Codec Status Undetermined" Please
By hypnoticpimp in forum Newbie / General discussionsReplies: 4Last Post: 30th Mar 2009, 14:29 -
Burning VOBs - error "Couldn't find any VOB unit"
By kshavo in forum Authoring (DVD)Replies: 7Last Post: 17th Feb 2009, 13:23 -
"ERR: MuxMan error!" while Creating DVD in GfD
By michcio in forum Authoring (DVD)Replies: 2Last Post: 6th Dec 2008, 18:05 -
FCP - "Title 3D" Missing - but it's not!
By ehmjay in forum MacReplies: 4Last Post: 23rd Jan 2008, 08:42
