Have updated to newer version and installed OK. Converted film fine but when swiched off PC and rebooted, SVCD would not open . Had to remove program and then reinstall. Works fine when on, it just seems not to work after a reboot. Anyone else having the same problem, or can someone shed any light on it?
Can you try the latest version to see if that solves the issue?
From the website:
Thanks for the advice. Have now got the latest version and everything seems fine now. Sorry I didn't get back to you sooner, but been a bit busy!
Avisynth reboot
By romanticwarrior in forum Video ConversionReplies: 1Last Post: 6th Oct 2010, 02:11 -
BD Rebuilder new version problem
By fazza8 in forum Blu-ray RippingReplies: 5Last Post: 20th Aug 2009, 07:36 -
QT issue ( self resolving w reboot)
By rotuts in forum MacReplies: 8Last Post: 14th Jan 2009, 16:28 -
SP3 reboot hell
By rubberman in forum ComputerReplies: 5Last Post: 14th Sep 2008, 01:34 -
XP - Reboot cycle
By Ai Haibara in forum ComputerReplies: 7Last Post: 3rd Sep 2008, 16:19
