Have tried to encode a couple of movie clips downloaded off a website into h.264 for PSP, but every time the PSP says 'unsupported data'.
Is this likely to be something wrong with the files in the first place or something I'm doing wrong?
When the clips have finished encoding there are two files, one called something like MAQ6489.video.MP4 and one called MAQ6489.audio.MP4.
I copy the video file to the Movies drop folder in PSPware and sync it but it doesn't show up on the PSP
If I remove the world video from the file, so it reads MAQ6489.MP4 and sync it the PSP does recognise it but won't play it, saying it's unsupported data.
My wife has encoded a couple of music videos, one taken from a CD and the other downloaded off Limewire and these both play fine.
Any ideas?![]()
Many thanks
The .video and .audio files are temporary files. They are not supposed to be renamed nor copied to the PSP, as they are automatically erased when the encoding finishes successfully. If that is not the case, clicking the blue "i" button in the progress window in search of an error message is mandatory.
Thanks for the reply.
Tried encoding a file today, it encodes about 70% then says finished.
Pressed 'i' on progress window. The only part that looks like an error message is right at the end. It says Codec type mismatch for mapping #1.1 -> #0.0.
.video and .audio files remain next to original file.
My output when Ffmpegx leaves me with the two temp audio and video files:
ffmpeg version CVS, build 3277056, Copyright (c) 2000-2004 Fabrice Bellard
Sat Apr 8 15:24:13 BST 2006
Mac OSX static build for ffmpegX
configuration: --enable-mp3lame --enable-gpl --disable-vhook --disable-ffplay --disable-ffserver --enable-a52 --enable-xvid --enable-faac --enable-faad --enable-amr_nb --enable-amr_wb --enable-pthreads --enable-x264
built on Dec 1 2005 03:50:24, gcc: 3.3 20030304 (Apple Computer, Inc. build 1666)
Input #0, mpeg, from '/Users/LiamBirch/Desktop/t1p1s15.vob':
Duration: 00:13:27.5, start: 7252.120000, bitrate: 7199 kb/s
Stream #0.0[0x1e0], 25.00 fps: Video: mpeg2video, yuv420p, 720x576, 8000 kb/s
Stream #0.1[0x8a]: Audio: 0x0000
Stream #0.2[0x81]: Audio: ac3, 48000 Hz, 5:1, 448 kb/s
Stream #0.3[0x80]: Audio: ac3, 48000 Hz, stereo, 192 kb/s
Stream #0.4[0x83]: Audio: ac3, 48000 Hz, stereo, 192 kb/s
Output #0, yuv4mpegpipe, to 'pipe:':
Stream #0.0, nan fps: Video: rawvideo, yuv420p, 368x208, q=2-31, 200 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Press [q] to stop encoding
x264 [info]: using cpu capabilities Altivec
mp4 [info]: initial delay 0 (scale 30000)
video:0kB audio:0kB global headers:0kB muxing overhead inf%
x264 [info]: slice I:321 Avg QP:26.00 size: 8156 PSNR Mean Y:40.78 U:42.47 V:41.93 Avg:41.16 Global:40.22
x264 [info]: slice P:23885 Avg QP:28.41 size: 1598 PSNR Mean Y:38.35 U:40.82 V:40.32 Avg:38.88 Global:37.23
x264 [info]: mb I I16..4: 34.1% 0.0% 65.9%
x264 [info]: mb P I16..4: 6.5% 0.0% 3.9% P16..4: 54.7% 0.0% 0.0% 0.0% 0.0% skip:34.9%
x264 [info]: final ratefactor: 25.86
x264 [info]: PSNR Mean Y:38.378 U:40.846 V:40.342 Avg:38.907 Global:37.256 kb/s:404.05
encoded 24206 frames, 14.49 fps, 404.15 kb/s
Stream mapping:
Stream #0.0 -> #0.0
x264 [info]: slice I:321 Avg QP:26.22 size: 7782 PSNR Mean Y:40.58 U:42.31 V:41.77 Avg:40.97 Global:39.94
x264 [info]: slice P:23885 Avg QP:28.15 size: 1587 PSNR Mean Y:38.52 U:40.80 V:40.11 Avg:38.99 Global:37.41
x264 [info]: mb I I16..4: 34.6% 0.0% 65.4%
x264 [info]: mb P I16..4: 6.2% 0.0% 4.4% P16..4: 47.9% 0.0% 0.0% 0.0% 0.0% skip:41.5%
x264 [info]: PSNR Mean Y:38.545 U:40.819 V:40.130 Avg:39.021 Global:37.438 kb/s:400.08
encoded 24206 frames, 16.40 fps, 400.18 kb/s
Seems that stream 0 comes from film source: 30000.00 (30000/1) -> 29.97 (30000/1001)
Input #0, mov,mp4,m4a,3gp,3g2, from '/Users/LiamBirch/Desktop/MAQ07970.video.mp4':
Duration: 00:13:27.6, start: 0.000000, bitrate: 401 kb/s
Stream #0.0, 29.97 fps: Video: h264, yuv420p, 368x208
Input #1, mpeg, from '/Users/LiamBirch/Desktop/t1p1s15.vob':
Stream #1.0[0x1e0], 25.00 fps: Video: mpeg2video, yuv420p, 720x576, 8000 kb/s
Stream #1.1[0x8a]: Audio: 0x0000
Stream #1.2[0x81]: Audio: ac3, 48000 Hz, 5:1, 448 kb/s
Stream #1.3[0x80]: Audio: ac3, 48000 Hz, stereo, 192 kb/s
Stream #1.4[0x83]: Audio: ac3, 48000 Hz, stereo, 192 kb/s
Output #0, mp4, to '/Users/LiamBirch/Desktop/MAQ07970.audio.mp4':
Stream #0.0: Audio: aac, 48000 Hz, stereo, 128 kb/s
Stream mapping:
Stream #1.1 -> #0.0 [sync #0.0]
Unsupported codec (id=86021) for input stream #1.1
Blu ray player (Phillips BDP2700/12) won't play some movies.
By lema1610 in forum Authoring (Blu-ray)Replies: 8Last Post: 12th Oct 2011, 08:48 -
Blu-Ray to Mp4 x.264 1080p won't play on PS3
By Patrick_H in forum Media Center PC / MediaCentersReplies: 3Last Post: 31st Dec 2010, 11:53 -
PSP saying unsupported Data.
By kumar66 in forum Newbie / General discussionsReplies: 7Last Post: 14th Nov 2009, 23:32 -
ffmpegX and PSP h.264
By str in forum ffmpegX general discussionReplies: 4Last Post: 25th Feb 2008, 09:08 -
New guy, movies won't play on certain DVD players?
By koreninja in forum DVD RippingReplies: 6Last Post: 12th Oct 2007, 23:53
