  1. Member SE14man's Avatar
    Jul 2005
    Queensland
    I want to format a hard disk drive but programming the autoexec to when i next restart without having to press y for yes at prompts.
    what would i need to put in the autoexec and where?
    cheers ppl.
  2. Deleted
  3. Member SE14man's Avatar
    Jul 2005
    Queensland
    Deleted
  4. I'm famous for that amongst friends. it is easy to do interactively, easier in fact.
    Applogies then.
    Still curious why you are going about it the hard way.
  5. Member SE14man's Avatar
    Jul 2005
    Queensland
    no problem man!
    May 2001
    Autoexec doesn't run for any of the non-DOS based operating systems (NT, 2000, XP, etc).
    Some programs can be activated by using the redirected input "key" (<). I don't think that FORMAT can use this method, but here's an example:
    FORMAT < YES.DAT
    And YES.DAT is just a simple file with a "y" and a carriage return.
    ICBM target coordinates:
    26° 14' 10.16"N -- 80° 16' 0.91"W
