Haven't seen a whole lot posted about this. We are currently making a special Video on CD, where the video is nothing more than an MPEG-1, and the player is based on FlashAnts FM Projector, using an embedded version of Windows Media Player 6.4. I should note that this final delivery is fairly set-in-stone, and its a LONG story that I don't want to get into. To make things simple, we MUSt end up with an MPEG-1, that is generally being played through Windows Media 6.4 (or any unknown version of quicktime, when played on a Mac).
The problem we are currently having is that the MPEG-1's playback has a subtle flicker, that is pronounced during certain scenes, but not so much during others. If needed, I can try to upload a small clip.
Here is the process currently in place:
The original source material is typically beta. The original video is edited on an aging Avid system on a Mac. An quicktime mov (uncompressed? - not sure) is exported from the Avid, and then imported into Premiere Pro 1.5 (Canopus-based hardware/codec), where further edits are made.
The final Premiere edit is then sent through a de-interlace filter, and encoded using MainConcept's MPEG-1 settings. We use MainConcept mostly because its quality really looks nice, but also because it allows us to change very specific settings for MPEG-1 video, particularly resolution (which has to be lowered) and bitrate. We generally bump up the bitrate a bit from the standard VideoCD settings, since the videos are fairly short and can easily fit on a CD.
Any thoughts? Are there any "flicker-removal" plugins or tools out there?
I seem to remember that when de-interlacing, you can do it odd or even. Using the wrong one could be causing the flicker.
Rob -
Not sure if you fixed this midimidi, but I've been having exactly the same problem and managed to pretty much sort it. It's not to do with interlacing, it seems to be directly connected to the MainConcept "Quality" setting when encoding mpeg1. It ranges from 1 - 5, at 5 (default) you get the bad flickering but at 1 it's completely gone. Of course, you lose quality (although not much in fairness) the lower the setting, but I found that at about 2 - 2.5 the flickering is still not noticeable and the video looks fine quality wise. Give it a go
Screen Flicker when using Photoshop 7.0
By chewie8008 in forum ComputerReplies: 4Last Post: 22nd Feb 2012, 08:57 -
Still have flicker after Denoising with AviSynth
By VideoFanatic in forum RestorationReplies: 279Last Post: 29th Jan 2012, 11:30 -
Flicker on DVD Menu
By Funky Monk in forum Authoring (DVD)Replies: 1Last Post: 12th Sep 2009, 18:42 -
Flicker on Roling Credits
By SCDVD in forum Newbie / General discussionsReplies: 17Last Post: 22nd Apr 2008, 21:36 -
Flicker effect
By wan2no in forum EditingReplies: 1Last Post: 26th Jul 2007, 21:38
