I am trying to convert downloaded television shows to MPG format for importing onto my Tivo using the Home Media Options. I use Videora Tivo converter which works well, but I manually have to start it. This program uses the FFMPEG converter to produce its output.
I want to call the FFMPEG program myself along with all of the necessary flags via my Bittorrent client so that after the program downloads, it automatically converts it.
Can anyone suggest a command line to simply convert these shows to a Tivo compliant MPG?
Results 1 to 1 of 1
Anyone Can Help to Convert This Preset to FFmpeg Command Line?
By raymng in forum Video ConversionReplies: 2Last Post: 26th Feb 2012, 12:11 -
ffmpeg / H264 (need help to build an optimized command line)
By iwiiiiiiiiii in forum Video ConversionReplies: 13Last Post: 22nd Oct 2011, 10:41 -
ffmpeg tga to x264 command line ?
By krohm in forum Video ConversionReplies: 71Last Post: 6th Jul 2010, 02:01 -
Using ffmpeg command line to convert a .vob(DVD) to avi/mpeg
By alfo666 in forum Newbie / General discussionsReplies: 1Last Post: 13th Sep 2009, 03:14 -
Definitive command line for ffmpeg conversion to ipod from tivo?
By orev in forum Video ConversionReplies: 1Last Post: 16th Jan 2008, 13:29
