Hello, I have read on here that you can convert PAL to NTSC by using VOB BLanker. Specifically, by right-clicking the video, after it's loaded into the program, and selecting "attributes."
My problem is, can anyone tell me what frame rate I need to set it to in order to get true NTSC output?
I ask, because I ran it through VOB Blanker but GSpot still says it is in PAL format.
I am frustrated. Can anyone help ?????
Thanks!!!!
Chris
Which guide ?
NTSC would be either 23.976 or 29.976 fps. 23.976 is closest to PAL and is the better option. But you also have to change frame resolution, which requires encoding. I'm surprised that VobBlanker can do that.Read my blog here.
Well, I don't know for sure. I just read on here that you can use VOB Blanker to convert PAL to NTSC. I've been looking for a simple way to do that, because I'm not familiar with all the aspects of trying to do this.
Maybe you are talking about the patch method, wich uses IFOEDIT.
https://forum.videohelp.com/viewtopic.php?t=221928
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
What is best way to convert vob files from pal to ntsc and vice versa?
By hibbs in forum Newbie / General discussionsReplies: 2Last Post: 14th Jan 2010, 20:41 -
PAL .VOB to NTSC .VOB Sound out of Sync
By zaque2004 in forum ffmpegX general discussionReplies: 4Last Post: 15th May 2009, 09:59 -
Best way to convert NTSC .VOB --> PAL .VOB
By macuser1960 in forum ffmpegX general discussionReplies: 1Last Post: 9th Mar 2008, 17:43 -
Convert NTSC VOB --> PAL VOB
By djdust in forum Newbie / General discussionsReplies: 2Last Post: 5th Dec 2007, 12:29
